automatic primary chain tensioners
Old 06-22-2011, 05:42 PM
fulldraw00's Avatar
fulldraw00
fulldraw00 is offline
Default automatic primary chain tensioners
recently I installed a chrome inner primary on my 06 roadking, while in there i installed a automatic primary chain tensioner, well come to find out after a few hundred miles the chain is to tight, so im going back in to set the chain properly, my question is this...is it fairley easy to compress and lock the tensioner so i can slide the assembly down?..is this a easy fix? i appreciate all your input and thanks in advance.
Old 06-22-2011, 05:56 PM
69cj's Avatar
69cj
69cj is offline
Wrap a nylon ty-rap around it and then cinch it down. Once out it's easy to compress further.
Old 06-22-2011, 06:05 PM
fulldraw00's Avatar
fulldraw00
thanks, kinda thought that but i i always feel better asking my fellow do it your selfers...
Old 06-22-2011, 06:26 PM
smithbrl's Avatar
smithbrl
smithbrl is offline
How does the tensioner get too tight? Is there a design flaw there? How do you know if your chain is too tight? Is this fairly common? Thanks
Old 06-22-2011, 06:32 PM
fulldraw00's Avatar
fulldraw00
i believe i dint leave enough play in the chain when i tightend down the tensioner..i check it today and i only had about a 1/4 in play in the chain, makes the pimary sound different too...so ill go back in and compress the tensioner and lower it to give the chain more play..5/8 to 7/8 for my RKC being to tight can cause the parts to wear more quickley also
natural gasser
EVO
16
08-22-2019 09:43 PM
jpooch00
12-21-2012 08:24 AM
KBFXDLI
04-04-2008 05:01 PM
DaShoveled one
02-08-2008 11:18 AM
Paul32730
12-15-2007 10:43 PM
Quick Reply: automatic primary chain tensioners
