HD Detachable Sissy Bar and luggage rack
Old 06-22-2011, 04:53 AM
army_eod's Avatar
army_eod
army_eod is offline
Default HD Detachable Sissy Bar and luggage rack
I am looking to add a detachable sissy bar/back pad and luggage rack to a 2010 FLSTF. I like the rounded stock bars and racks in black. Anybody have any experience with this setup? I am probably looking at the HD parts.
Thanks in advance.
Old 06-22-2011, 05:35 AM
herbie021's Avatar
herbie021
herbie021 is offline
I got the HD detachable sissy bar (tall, round and black) for my 2010 Fat Boy Lo. By the time you get the signal light relocation kit and mounting hardware it gets a bit pricey but well worth it. I just took it to the dealership for install as it needed its maintenance anyways.
Old 06-22-2011, 06:38 AM
TX Lo Life's Avatar
TX Lo Life
TX Lo Life is offline
I have the CrossBones style detachable sissy bar as well as the round tubed detachable sissy bar/luggage rack. Both work great. Keep an eye on Ebay... I found the sissy bar/luggage rack detachable with pad on there for 200. Had it powder coated gloss black for 25. As stated above they can get pricey once you put all the parts together from HD. I don't use mine much so I wasn't willing to spend what they wanted. However... I can see the value to those that use them...very handy.
Old 06-22-2011, 08:42 AM
shineybike's Avatar
shineybike
shineybike is offline
If you ever plan on adding saddle bags make sure you get the detachable side plates for the backrest that have the notch cut out to accomodate the saddle bag mounting posts. They would be like the ones used on a Heritage. I would keep an out on ebay, they come up fairly often.
Old 06-22-2011, 09:25 AM
iupsig97's Avatar
iupsig97
iupsig97 is offline
Have the detachable setup. Love it. Easy on/off and makes it a lot easier when you need to pull the seat off for whatever reason.
Old 06-22-2011, 12:42 PM
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
Really no need to relocate the signals or buy the kit. You can modify the detach mount to make it fit.
Old 06-22-2011, 06:29 PM
TNB's Avatar
TNB
TNB is offline
Thanks in advance.
Most of the time mine are off, but it's nice to be able to add it at a moment's notice. Same with the bags and passenger seat.
Old 06-22-2011, 11:22 PM
Bluehighways's Avatar
Bluehighways
Bluehighways is offline
I have the stock sissy bar and the HD luggage rack attached to it using the quick detach side plates. I also use the Barebacks quick detach kit for the bags. This makes for a very convenient change from touring to local two-up to solo riding in just a couple of minutes. Also, and maybe even more important, it makes the bike way easier to clean!
Old 06-23-2011, 12:28 AM
tunaman's Avatar
tunaman
tunaman is offline
Precisely, as well as the windshield! Great to have convertible options to fit the circumstances... go from full dressed to stripped solo in 5 minutes or less.
Roger
Old 06-23-2011, 09:53 AM
RICHIEMACK's Avatar
RICHIEMACK
RICHIEMACK is offline
You have to grind a little off the locks on the detach for it to fit over the blinkers....cross bones s. Bar..harley parts got mine on ebay.with rack $120
Quick Reply: HD Detachable Sissy Bar and luggage rack
