Bendix carb tuning
Old 06-17-2011, 11:01 PM
dirty78ironhead's Avatar
dirty78ironhead
dirty78ironhead is offline
Default Bendix carb tuning
I got a 78 with a bendix carb and ultima electronic ignition. I set the jets at 1.5 for slow and 4 out for main to start. I am getting some popping out of the carb from time to time...so its to lean correct. So I gave it some more fuel. I am still getting some pops from carb and the plugs look rich so what am I Doing wrong ? The bike idles good and when I run up thru the gears it seems to run good. Any advice would be great.
Thanks
T-Ron
Old 06-18-2011, 07:14 AM
IronMick's Avatar
IronMick
IronMick is offline
Bendix carb info here ...
Bendix Carb
Old 06-18-2011, 08:17 PM
piniongear's Avatar
piniongear
piniongear is offline
Thanks
T-Ron
Here is how you tune a Bendix having the adjustable main jet......
pg
Old 06-28-2011, 10:42 PM
dirty78ironhead
So I followed all instructions on tuning posted by PG read all of the post here and on the other XL forum recomened form Mick. Still getting a pop out of the carb. Just went for a 300 mile round trip ride and the old sled ran great but would still pop every now and then so what gives? I used to have the fuel line from the petcock dropping down under the carb and then to the inlet never had a pop. Now I have a 90 degree petcock and the fuel line goes almost straight in with the inline filter. Would this make a diff ? Also the clear filter some times is full and sometimes not.
Thanks for any input
T-Ron
Old 06-28-2011, 11:22 PM
dirty78ironhead
Should also say that the pop happens when coming to a stop and I just blip the throttle to down shift are when taking off again just small throttle input.
Thanks
T-Ron
piniongear's Avatar
piniongear
A pop tells me there is still an air leak.
The position of the petcock makes no difference.
Air bubbles in the clear line mean nothing. Quite normal.
After a 300 mile ride you may want to check the pushrod clearance again. Do this with a stone cold engine.
pg
Old 06-29-2011, 06:21 AM
IronMick's Avatar
IronMick
IronMick is offline
... and the fuel line goes almost straight in with the inline filter ...
Do you have both a petcock filter inside the fuel tank and the in-line filter? If so remove one of them. There have been many instances of fuel flow being restricted when using two fuel filters.
Also, is the in-line filter a motorcycle specific filter, and is it designed specifically for gravity flow? There have been many instances of fuel flow being restricted when using an automotive fuel filter designed for vehicles with a fuel pump.
Old 10-21-2019, 06:01 AM
saves's Avatar
saves
saves is offline
1st Gear
Default Pop through carburetor
To check for manifold leaks remove spark plug and screw in a hose to attach an air compressor, block carburetor filter end and pressurize slightly., now spray manifold joints and carburetor with soap and water to find vacuum leaks.Float setting and action is crital .
Old 10-22-2019, 06:18 AM
IronMick's Avatar
IronMick
IronMick is offline
The above post contains much incorrect advice. To check for manifold leaks, read the following thread before considering the advice given in the above post...
http://xlforum.net/forums/showthread.php?t=2074920
triple604
Engine Mechanical Topics
03-07-2017 05:52 PM
WellHungWillie
09-14-2014 07:35 PM
FrankieASikeston
Ironhead
10-25-2012 11:58 AM
johangastorp
EVO
25
09-12-2012 11:46 AM
Grog
Carburetor Related
01-20-2010 09:43 PM
Quick Reply: Bendix carb tuning
