Saddlebag inserts change size????
Old 06-13-2011, 04:45 PM
nupdcop's Avatar
nupdcop
nupdcop is offline
Default Saddlebag inserts change size????
Hey all. I'm a new owner of a 2008 HD Electra Glide FLHTP. I've been looking around at saddlebag inserts to replace the faded "POLICE" logo that was remvoed by the previous PD. I can't spend tons of money and am looking for something simple to peal and stick for now.
The question/problem that I am running into is that I've heard that the saddlebag inserts were changed from 2007 to 2008. Meaning that there are "old" style before 2007 and "new" style starting in 2008.
I've looked and I can't see the difference so if there is any it must be in the size because shape still looks the same to me. My local HD guy can't seem to tell me either way... jsut wants to sell me something - whcih I can't buy his anyway as I don't have that kinda cash - these on line sellers say that there is and some say there isn't.
Anyone know the truth behind this? I was told the "POLICE" inserts are part number 1993 and can be used from 1993-2011 - I can paint them black if this is the case just to fill the space. Please let me know - be kind to the new guy.... after all I just upgraded from a kawasaki - uggg shouldn't have said that!!!
Old 06-13-2011, 05:42 PM
robfaulkner's Avatar
robfaulkner
robfaulkner is offline
Default homemade inserts
I cut plastic in the same shape as the recessed area, painted them a matching off-white, installed them using 2 sided automotive trim tape and then relocated the saddlebag reflectors on the inserts. Check my signature pics to see what I'm trying to describe. Cost - $0. Just a bit of time and on-hand shop supplies.
Old 06-13-2011, 05:44 PM
robfaulkner
Default cop bag hinges
PS The hinges on the bags are ugly, but can be easily replaced with the premium tour-pak hinges. A huge improvement!
Old 06-13-2011, 07:23 PM
18BKLR's Avatar
18BKLR
18BKLR is offline
Look in my sig pic. You can see the inserts I have. They are turned off in that pic. With the accessory plug I turn them on and they are LED red. Pretty nice for around 80 bucks. They stick in with 3m heavy duty double stick.
Old 06-25-2011, 10:51 AM
rushbass's Avatar
rushbass
rushbass is offline
I installed some cheap plastic inserts with double-stick tape... got them off ebay. Yep, they are cheap, but look fine... I wouldn't spend a lot of money on this aspect. You could go to a local sign shop, and get them to cut some plastic to fit.
You are right, in that the hole is a different size on the 2008 and up... I never could find a set that was a perfect fit... basically the older model style is a little shorter, so it won't fill the hole completely on the front facing end...
Old 06-25-2011, 10:59 AM
rushbass's Avatar
rushbass
rushbass is offline
Here is a close up of my inserts... you can see how the size of the insert does not completely fill the hole, or follow the exact contour of the angle towards the front:
SCJE8
12-21-2010 10:23 AM
avcaruso
Shovelhead
05-08-2010 02:06 PM
hydrolock43
05-03-2010 06:37 PM
vickon
10-31-2009 08:30 PM
jbhawley
12-24-2008 01:29 PM
Quick Reply: Saddlebag inserts change size????
