Transmission oil level check on 883n
Old 06-11-2011, 09:10 PM
volks-man's Avatar
volks-man
volks-man is offline
Default Transmission oil level check on 883n
I own a service manual...... But it's at home and me and the bike are not.
I removed the derby cover and lost some oil when changing the clutch cable (on side stand). The parts guy at the dealer sold me a quart to top it off.
Short of a full drain and refill....
How do I check the level?
Old 06-11-2011, 09:19 PM
nciron883's Avatar
nciron883
nciron883 is offline
All it takes is a quart to fill it .. just drain and refill
Old 06-11-2011, 09:23 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Ragnar Danneskjöld is offline
Depends on which bike you have, but I think it's mostly the same for Sporty's.
You should be able to put the side stand on, open the derby cover, and the oil should sit at the bottom of the clutch.
Old 06-12-2011, 02:31 AM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
If you are just topping it off, set it upright using a block of wood or something under the stand (or have someone hold it upright for you), fill to the bottom of the derby cover, then reinstall the cover.
Old 06-12-2011, 06:46 AM
volks-man's Avatar
volks-man
Thanks guys!
Old 06-17-2011, 03:54 PM
boduke883's Avatar
boduke883
boduke883 is offline
Hey which oil did you use? I assume the tranny and the primary oil are the same.
Old 06-17-2011, 04:31 PM
Ragnar Danneskjöld
Yup..
Old 06-17-2011, 04:45 PM
boduke883's Avatar
boduke883
i read on another thread that it's ok to use Mobile 1 75-90. But the only Mobile 1 75-90 oil I found was gear oil. Is that the same thing?
Old 06-17-2011, 04:55 PM
volks-man's Avatar
volks-man
huh, good question....
my cousin poured it in and buttoned the derby up. to be honest i haven't a clue what the oil was except it came from the dealer.
Old 06-17-2011, 06:57 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Yes, Mobil 1 75-90 gear oil is all I use in the primary.
TwoBlue02
06-25-2012 09:26 AM
pchrcane65
07-13-2009 09:02 PM
88nightster
04-22-2009 02:55 PM
06ClassicRider
11-01-2007 01:12 PM
acadien
04-11-2007 09:42 PM
Quick Reply: Transmission oil level check on 883n
