Diagnostic Trouble Codes / Error Codes
Old 06-01-2011, 12:48 PM
blueangel73's Avatar
blueangel73
blueangel73 is offline
Default Diagnostic Trouble Codes / Error Codes
I am not sure if this is the right place to post these, but I have notice that people are often asking what the codes mean or how to find them. So here ya go.
I hope this help the people that need it!
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" (no response) will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
P0605 ECM FLASH Memory Error
P0603 ECM EEPROM Memory Error
U1300 ECM Serial Data Low
U1301 ECM Serial Data High
U1097 Loss of Speedometer Serial Data to ECM
U1064 Loss of TSM/FSFM Serial Data to ECM
P1003 System relay contacts open
P1002 System Relay Coil High/Shorted
P1001 System Relay Coil Open/Low
P1004 System Relay Contacts Closed
P1009 Incorrect Password
P1010 Missing Password
P06415 V+Vref 1 Out Of Range
P06515 V+Vref 2 Out Of Range
P0373 CKP Sensor Intermittent
P0107 Map Sensor Open/Low
P0108 Map Sensor High
P0374 CKP Sensor Synch Error
P1511 Throttle actuator control power management failure of throttle control actuator
P1600 EFI Module Processor Internal Error
P1270 TGS Validation Error
P2107 EFI Module Processor Internal Fault
P2101 Throttle actuator control motor circuit range/performance error
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
P2138 TGS Correlation Error (Twist grip sensor)
P0120 TPS1 Range Error
P0220 TPS2 Range Error
P0122 TPS1 Low
P0123 TPS2 High/Open
P0222 TPS2 Low
P0223 TPS2 High/Open
P2135 TPS Correlation Error
P2119 EFI Motor Throttle Body Range Performance
P2100 EFI Motor Circuit Open
P2101 EFI Motor Circuit Range Performance (Actuation Error)
P2102 EFI Motor Circuit Low
P2103 EFI Motor Circuit High
P2176 EFI Closed Position Not Learned
P1514 Air Flow Fault
P2105 EFI Forced engine shutdown
P1501 Jiffy Stand Sensor Low
P1502 Jiffy Stand Sensor High
P0572 Brake Switch Low
P0117 ET Sensor Low
P0118 ET Sensor High
P0112I AT Voltage Low
P0113I AT Voltage Open/High
P1351 Front Ignition Coil Driver Open/Low
P1354 Rear Ignition Coil Driver Open/Low
P1352 Front Ignition Coil Driver High/Shorted
P1355 Rear Ignition Coil Driver High/Shorted
P1357 Front Cylinder Combustion Intermittent
P1358 Rear Cylinder Combustion Intermittent
P0261 Front Injector Open/Low
P0263 Rear Injector Open/Low
P0262 Front Injector High
P0264 Rear Injector High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0501 VSS Sensor Low
P0502 VSS Sensor High/Open..
P1356 Rear Cylinder No Combustion
P1353 Front Cylnder No Combustion
P0444 Purge Solenoid Open/Low
P0445 Purge Solenoid High
P1475 Exhaust Actuation Position Error
P1477 Exhaust Actuator Open/Low
P1478 Exhaust Actuator Shorted/High
P0131 Front Oxygen Sensor Low
P0151 Rear Oxygen Sensor Low
P0132 Front Oxygen Sensor High
P0152 Rear Oxygen Sensor High
P0134 Front Oxygen Sensor Inactive
P0154 Rear Oxygen Sensor Inactive.
P1510 EFI Limited Performance Mode
P1511 EFI Power Management Mode
P1512 EFI Forced Idle Mode
P0577 Cruise Control Input High
U1300 Serial Data Low
U1301 Serial Data High
U1016 Loss of ECM Serial Data
U1255 Serial Data Error
B1142 Smart Security System Internal Fault
B1135 Accelerometer Failed
B1136 (HFSM) Accelerometer Tip Test Error
B1151 Bank Angle Sensor(BAS) Short to Ground
B1152 Bank Angle Sensor(BAS) Short to Battery
B1153 Bank Angle Sensor(BAS) High
B1154 Clutch Switch Input Short to Ground
B1155 Neutral Switch Input Short to Battery
B1134 Starter Output High
B1121 (TSM) Left Turn Output Fault
B1121 (HFSM) Left Turn Output Open
B1122 (TSM) Right Turn Output Fault
B1122 (HFSM) Right Turn Output Open
B1123 (HFSM) Left Turn Output Short to Ground
B1124 (HFSM) Right Turn Output Short to Ground
B1125 (HFSM) Left Turn Output Short to Battery
B1126 (HFSM) Right Turn Output Short to Battery
B1143 (HFSM) Security Antenna Short to Ground
B1144 (HFSM) Security Antenna Short to Battery
B1145 (HFSM) Security Antenna Open
B0563 Battery Voltage High.
B1131 (HFSM) Alarm Output Low
B1132 (HFSM) Alarm Output High
B1141 (TSM) Ignition Switch Low/Open
B1141 (HFSM) Ignition Switch Low/Open
The following came from the ABS section of the 2008 Electrical Diagnostics manual- hopefully close enough until something better comes available...
C0562 Device voltage low
C0563 System voltage high
C1014 ECU internal fault
C1017 Pump motor power circuit open fault
C1018 Pump motor ground high resistance fault
C1021 Front wheel speed sensor equals 0
C1023 Rear wheel speed sensor equals 0
C1025 Front wheel speed signal intermittent
C1027 Rear wheel speed signal intermittent
C1032 Front wheel speed sensor circuit open or shorted
C1034 Rear wheel speed sensor circuit open or shorted
C1042 Pump motor open
C1043 Pump motor stalled
C1055 ECU internal fault
C1056 ECU internal fault
C1057 ECU internal fault
C1061 ECU internal fault
C1062 ECU internal fault
C1065 ECU internal fault
C1066 ECU internal fault
C1094 Front brake switch always on
C1095 Front brake switch open
C1118 ECU internal fault
C1121 ECU internal fault
C1151 Front wheel release too long
C1153 Rear wheel release too long
C1158 Calibration programming required
C1206 Wheel speed sensor frequency out of range
C1208 Wheel speed sensor frequency out of range
C1212 Front or rear brake not applied with decel
C1214 Rear brake switch always on
C1216 Rear brake switch open
U1300 Serial data low
U1301 Serial data open/hi
Old 08-20-2011, 04:07 PM
chrls's Avatar
chrls
chrls is offline
Great post, thanks.
skos
129
11-26-2022 01:33 PM
wayne schwedler
10-24-2012 04:50 PM
gunner11
11-09-2010 02:20 PM
OCD
10-28-2010 07:38 AM
Yardstick
09-17-2010 05:04 PM
Quick Reply: Diagnostic Trouble Codes / Error Codes
