sportster fuel reserve
Old 05-23-2011, 07:24 PM
Timothy Houser's Avatar
Timothy Houser
Timothy Houser is offline
Stage II
Default sportster fuel reserve
Just bought a 2001 1200 custom, how often should you use the fuel in the reserve, or does the fuel thats in the reserve automatically get syphoned into the tank when you refill? If you dont use the fuel in reserve wouldn't it go bad?
Old 05-23-2011, 07:48 PM
Timothy Houser
Stage II
Old 05-23-2011, 07:59 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
The reserve in the tank is not a seperate compartment in the tank. The petcock has 2 places to take fuel from the tank, one is higher than the other. When the petcock is in the ON position it takes fuel from the upper opening and when the fuel level gets below that level it acts like it ran out of gas. Then when you switch the valve to the RESERVE position, it sucks gas from the lower opening. When the fuel level gets below that level, then you will be pushing the bike to the nearest gas station.
k&j eglide's Avatar
k&j eglide
k&j eglide is offline
There isn't a separate fuel supply for the reserve vs main. Imagine a straw sticking up into the tank. It can only recieve fuel from the top. When no more fuel can come in (because the level has dropped below the straw), you switch to reserve, which simply lowers the straw. Same gas, always being mixed as you ride or refuel. If you have the inclination, shut off your gas supply at the petcock, remove your tank (and fuel supply line to carb) drain the tank thru the gap cap side and remove the petcock. All will be clear.
Old 05-23-2011, 09:44 PM
elkhunter719's Avatar
elkhunter719
elkhunter719 is offline
[quote=k&j eglide;8360620]There isn't a separate fuel supply for the reserve vs main. Imagine a straw sticking up into the tank. It can only recieve fuel from the top. When no more fuel can come in (because the level has dropped below the straw), you switch to reserve, which simply lowers the straw. Same gas, always being mixed as you ride or refuel. If you have the inclination, shut off your gas supply at the petcock, remove your tank (and fuel supply line to carb) drain the tank thru the gap cap side and remove the petcock. All will be clear.[/quo
Kind of drastic measures to take just to prove that there are two different levels to the petcock level!
Old 05-24-2011, 01:36 AM
MrCookie's Avatar
MrCookie
MrCookie is offline
That's kinda what I did to find out. I was switching tanks and needed the old petcock. I thought I didn't have a reserve on my bike. turned out I was running on reserve the whole time. at least I only have to push the bike only once.
Old 05-24-2011, 09:08 PM
heybaylor's Avatar
heybaylor
heybaylor is offline
good idea to switch to "reserve" every once in a while ..
"clears the trash that might get into it "
real bummer to have to go on reserve and find out that the petcock is clogged
supermanotorious
10-14-2015 12:16 PM
MJHJEA
EVO
11
09-05-2014 06:47 PM
Harley_Charley
01-04-2014 08:31 PM
Tiggeresq
03-27-2007 02:33 PM
DAILYRDR
Exhaust System Topics
01-15-2007 12:45 PM
Quick Reply: sportster fuel reserve
