New here, 1200 Stroker Kit question....
Old 07-04-2005, 05:27 PM
bullittmcqueen's Avatar
bullittmcqueen
bullittmcqueen is offline
Stage IV
Default New here, 1200 Stroker Kit question....
hey guys, just got a bike and enjoying it. Wanting to punch out the 883 to a 1200 and a couple friends told me it was fairly inexpensive.....where's the best place to look? any links are much appreciated! Thanks!
Old 07-05-2005, 01:25 AM
pococj's Avatar
pococj
pococj is offline
Default RE: New here, 1200 Stroker Kit question....
The MoCo kits are fine, and so are the S&S. Going from 883 to 1200 isn't a stroker kit, just uses bigger bore barrels. The 883 bore & stroke is 3.00 x 3.81, and the 1200 is 3.50 x 3.81.
Old 07-05-2005, 10:59 AM
bullittmcqueen
Stage IV
thanks for the info, as i am new to bikes i didnt know that the strokes were the same.
any others? i have heard a couple people say it was less than a thousand dollars? is that right?
Old 07-05-2005, 02:44 PM
Thumper26's Avatar
Thumper26
Thumper26 is offline
You can always try J&P's conversion kit at this link:
http://www.jpcycles.com/productgroup...1-E22510961432
At $529.99 it sounds & looks like a nice inexpensive way to get the punch you're after!
Good luck with your wrenching!
Thumper26
Old 07-06-2005, 01:13 AM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
just my .02 the screamin eagle kit is around 450, and has forged pistons, some of the other kits have cast pistons. most harley dealers will do it for 850-950 usually in one day.
Old 07-06-2005, 09:25 PM
bullittmcqueen
Stage IV
thanks for the info guys, i had heard good things about the Harley kit and that $$$ makes it look very good........thanks again
Old 08-21-2005, 02:32 PM
xlrider's Avatar
xlrider
xlrider is offline
NRHS has alot of good sporty perforamnce stuff. If you do the wotk yourself you will save a bunch of money and be able to throw head work or cams in there.
I never worked on a bike before, but did my top end rebuild myself , it only took a day to do.
Old 08-24-2005, 04:50 PM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
Taking a 883 to a 1200 is a great thing. But using 883 heads on a 1200 is not so great. Long story short the 883 head will not work likea 1200 head. The kit many use is less money , using a dished piston to keep comp ratio in check. The best bang for you buck is to use Thunder storm heads From HD and there H/C pistons , and the xl bolt in cams and with tuning 90HP is with reach. The early 1200 buel was 90 hp out of the box.
Now we skip forward in time to present day and you can install 1250 kit. I have built several of these and they are down right scary fast. Use Buel heads ( 500 for the pari from hd) the 1250 kit a set of cams and you are pushing the 105+ hp mark. Try vertical wheelies in 2nd and 3rd on a 1200's . The plus is that the cylinders are nikasil so there is no case mods to go this big, there is a lifetime warranty on the cylinders, pistons and gaskets come with the kit. And you will see 20-30 less oil temps. Not to mention have one bad *** sporty. I built one and I ride with the guy and I cannot pull him until I shift from 2nd to 3rd gear. Then the big cubes walk away but stop light to stop light a very close race. Many time he gets me by a legnth or two until I get the 3rd gear and I kindly remove his paint on the way by.
I sell the kit I am talking about and use the same kind on cylinder on my bike . The kit is a great way to go to have a bigger i nch sporty without boring case to get cylinder spigots to fit
Dave_E
08-14-2020 06:34 AM
derek_661989
11-09-2019 07:48 PM
peteknok06
01-11-2015 07:47 PM
chrism84
03-16-2007 11:20 PM
Dave_E
Exhaust System Topics
08-08-2006 09:26 AM
Quick Reply: New here, 1200 Stroker Kit question....
