Tire Pressure
Old 05-09-2011, 05:47 PM
BinIdaho's Avatar
BinIdaho
BinIdaho is offline
Default Tire Pressure
I know this has been discussed before...since then there's been more Tri-Glide owners here thought we should do a repeat.
I have 36# (front) and 26# (rear)....what tire pressure is everyone else using? Do you increase the tire pressure for long trips or run the same poundage year-round?
Thanks in advance
Old 05-09-2011, 05:49 PM
krw's Avatar
krw
krw is offline
I also keep it 36-26. Ride it all the time at these pressures.
Old 05-09-2011, 06:27 PM
icebite1's Avatar
icebite1
icebite1 is offline
36-26 here also
Old 05-09-2011, 09:06 PM
carlo's Avatar
carlo
carlo is offline
26 rear 36 front All the time.
Old 05-09-2011, 10:48 PM
T K Glider's Avatar
T K Glider
T K Glider is offline
Ditto
Old 05-10-2011, 04:25 AM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
36 front and 24 rear all the time.
Old 05-10-2011, 06:07 AM
Boom's Avatar
Boom
Boom is offline
36 front, 26 rear always
Old 05-10-2011, 06:47 AM
Buddy WMC's Avatar
Buddy WMC
Buddy WMC is offline
36 Front, 28 Rear and mine are also Nitrogen filled. FWIW, my tire dealer here is a 20 year friend and expert in his field. His explanation for the 2 extra lbs in the rear was that the tires would last longer with the extra weight two up most of the time.
Old 05-10-2011, 07:55 AM
hotshoe's Avatar
hotshoe
hotshoe is offline
36# front 26# rear at all times. Ride two up 95% of the time.
Old 05-10-2011, 10:07 AM
fogrider's Avatar
fogrider
fogrider is offline
Default tires
26 front, 24 rear, to me 24 is a little more comfortable. On a trip we keep the shock close to 50#, around 30# when were not loaded up
Quick Reply: Tire Pressure
