Tips for changing kickstand spring?
Old 04-22-2011, 06:28 PM
HOG_WILD_STEVE's Avatar
HOG_WILD_STEVE
HOG_WILD_STEVE is offline
Default Tips for changing kickstand spring?
I need to change the spring on my wifes 96 1200. Any special tip? Never done this before. Any and all would be appreciated.
Old 04-22-2011, 06:38 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
put kick stand down and load the spring with pennies. put kickstand up and spring will come right off.
bend new spring and load with pennies. put on the bike with kickstand up. put kick stand down and pennies fall right out.
hint: make sure you have a friend hold the bike for you.
Old 04-22-2011, 06:43 PM
hjc950's Avatar
hjc950
hjc950 is offline
I just changed them on both of my Sportsters.
Strapped the bike horizontally to the walls of my garage for stability (while on jack)
Removed the Pretzel clip from the pivot pin and tapped it out. This let the stand fall out releasing the Spring.
Put stand back in using new clip (or cotter pin)
Stretched the new spring in place using a Automobile "Drum Brake" spring tool.
About 5 minutes not counting lifting and strapping off the bike.
HJC
Old 04-22-2011, 07:04 PM
Dango's Avatar
Dango
Dango is offline
[QUOTE=xFreebirdx;8225024]put kick stand down and load the spring with pennies. put kickstand up and spring will come right off.
That's just what I did. The hard part was bending the new spring to insert pennies. Wear thick leather gloves and, while bending it, have someone else insert the pennies for you.
HOG_WILD_STEVE
I like the penny idea. How do you spread the new spring open enough to get pennies into it?
HOG_WILD_STEVE
Someone should make a youtube video of how to do this.
Old 04-22-2011, 09:35 PM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
Might as well replace the bushings on the pivot pin. Here's a new one next to one that's about two years old.
Old 04-23-2011, 12:39 AM
joebotics's Avatar
joebotics
joebotics is offline
wear eye protection!
Old 04-23-2011, 01:14 AM
HOG_WILD_STEVE
So i used the pennies and got the old spring off and the new one on. Seems like the spring wasn't the problem after all. I needed a new one anyone since the old one was rusted. The new one seems a little better but the kickstand still wiggles around a lot when it's up. There's a lot of play in it. This might be beyond my abilities. I think I'll call Harley tomorrow to make an appointment for them to look at it.
Old 04-23-2011, 10:18 PM
HarleyScuba
Replace the pivot bushings to take up any slop. Make sure the spring hooks are oriented properly. I know the hook orientation thing sounds like bullshit, but it seems to have made a slight difference in how snug the jiffystand retracts.
Below is before I replaced the spring and bushings. Also, the penny trick (I used thick washers) works perfect for removing the old spring, but when I tried that technique replacing it, it seems the spring got tweeked and wasn't the same. I had another new spring laying around and I installed it by brute force and needle nose pliers. Now, the jiffystand sits against the rubber bumper.
Quick Reply: Tips for changing kickstand spring?
