Tips for changing kickstand spring?
Old 04-24-2011, 01:28 AM
MrCookie's Avatar
MrCookie
MrCookie is offline
Does any one have the part number for the bushings? I have the same issue too. replaced the spring and still has a lot of slop in it. So much that it drags on left turns. I bolted a piece of wire hanger and a compression spring to the primary chain tensionor and to the cotterpin that holds the kick stand up. it does help for a while, but it does move out of alignment after a while.
Old 05-13-2013, 10:30 AM
Shorty00645's Avatar
Shorty00645
Shorty00645 is offline
Not all bikes have bushings. My 92 Sporty doesn't have them.
Old 06-11-2014, 03:26 PM
priced324's Avatar
priced324
priced324 is offline
Stage I
A lot of great ideas here,appreciate all,just did the spring on my sportster used my floor jack to spread the spring then used the penny trick.worked great.Also I hooked the spring onto the jack axle using a small carabiner
Old 06-12-2014, 03:36 PM
uncle kebo's Avatar
uncle kebo
uncle kebo is offline
Received 4,369 Likes on 2,205 Posts
In all seriousness, use safety goggles.. I had one slip and I caught it in the nose, SCARED the crap outta me
Old 06-12-2014, 09:28 PM
RickRock's Avatar
RickRock
RickRock is offline
I went with the pulling of the pin route, with bike leaning against wall. Not that hard to put in when approached from UP position. Does make a difference in how the springs hooks are aligned. Mine was still loose - so I took kickstand off again and beat down the tab on stand that holds spring with a big hammer to increase spring span. It doesn't jiggle around anymore when riding. I never noticed or cared how it looks; its all tucked underneath everything when I'm riding.
Old 06-26-2014, 09:03 PM
Tom_Harleson's Avatar
Tom_Harleson
Tom_Harleson is offline
Default 12 cents
Great thanks!!
11 cents made it a 5 minute job!!!
Ride safe,
Tom
Old 04-09-2022, 10:49 AM
joshuahd15.va's Avatar
joshuahd15.va
joshuahd15.va is offline
Stage I
Originally Posted by HOG_WILD_STEVE
Someone should make a youtube video of how to do this.
there are several videos on how to replace spring.
Old 04-09-2022, 11:28 AM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
Rob Roy's Revenge is online now
Originally Posted by Tom_Harleson
Great thanks!!
Ride safe,
Tom
I replaced the jiffy stand on my 2011 XL883N by placing ten 1p coins in between the coils and with the spring is located I pulled out the coins one at a time with a pair of pliers.
I originally removed the stand to get the chrome removed and have it powder coated gloss black.
Old 04-09-2022, 07:36 PM
apache snow's Avatar
apache snow
apache snow is offline
HOG_WILD_STEVE hasn't been on here since 10/20/2011 but if he ever comes back and seen this he will be happy.
Old 04-10-2022, 11:41 AM
John Harper's Avatar
John Harper
John Harper is online now
Received 1,643 Likes on 1,133 Posts
I used a Home Depot Everbilt 4" spring. Took off the jjify stand bumper, old spring off, new spring on. The Home Depot spring actually pulls the stand up against the bumper, where the stock one (and a replacement I tried) still let it hang down a bit. No need for pennies or using a jack to pull spring apart before install.
John
Rob Roy's Revenge (04-10-2022)
Quick Reply: Tips for changing kickstand spring?
