S&S oil pump & EVO
Old 04-22-2011, 10:34 AM
evofloyd's Avatar
evofloyd
evofloyd is offline
Default S&S oil pump & EVO
Did any one else put an s&s oil pump on their EVO ? what a pain it was with oil pressure. Its a high volume pump, not high pressure. The stock oil filter didnt work, went with a k&n high flow filter, and was told by k&n I would not lose filtration, but who knows.
Was just wondering it any one else was running a s&s pump on their evo and had the same trouble.
Stock filter 60# psi cold,and it would come out the push rod covers. Was heating the bike up with a space heater before starting. K&N filter 40# psi cold. Hot it runs 15+ at an idle.
Old 04-22-2011, 09:41 PM
topfuel7's Avatar
topfuel7
topfuel7 is offline
The reusable stainless filters would probably solve that problem. One reason professional teams use them is because they are non restrictive. The nascar guys probably use serious high flow pumps.
Old 04-23-2011, 04:55 AM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Sounds like the K&N was the cure...they pretty much can be trusted to know what they are talking about...if any USA based firm makes a statement they could be sued for you can bet they did their homework!!!!
Old 04-23-2011, 05:59 AM
evofloyd's Avatar
evofloyd
evofloyd is offline
Default K&N
Yep K&N was the trick, still have not found any one who put a S&S pump on a Evo, I know I'm not the first.
Old 07-18-2011, 09:55 AM
drachman's Avatar
drachman
drachman is offline
Stage I
Unhappy
Yes, I have fitted an S&S pump to my '96 FLHR. Same issues here as with yours. I'm worried that in fact the oil isn't getting to the top end - I'll check this again.
Old 07-18-2011, 11:26 AM
jsbridgew's Avatar
jsbridgew
jsbridgew is offline
i've got an S&S on mine... but it's not the 'high volume' pump.... got just a stock replacement... was told the 'high volume' pump isn't good for the EVO's....but heck, if the K&N solved the problem, then cool
Old 07-20-2011, 09:25 AM
evofloyd's Avatar
evofloyd
evofloyd is offline
Well the S&S pump is fine. When I put the pump on I also put a 4 core jagg oil cooler on at the same time. The extra 30 % oil flow didnt want to pass through the cooler. I ended up pulling the cooler off. Now I know should have used at lest a 6 core cooler.
Cold the oil pressure is around 40#, hot at an idle 15# with 20-50. Next oil change going to straight 50
Old 07-20-2011, 03:10 PM
Havoc88's Avatar
Havoc88
Havoc88 is offline
Hey man, thanks for the update, its nice to know when someone solves a mystery problem like that, especially when the solution is one of those that give you the WTF feeling LOL
Glad ya got it solved!
Old 07-22-2011, 09:48 AM
mostSilly's Avatar
mostSilly
mostSilly is offline
I have an S&S pump on mine, '88 FLHS, BUT I don't know what model pump, not do I have an oil pressure gauge. Looks like I have some homework ...
Old 07-22-2011, 04:57 PM
evofloyd's Avatar
evofloyd
evofloyd is offline
Default guage
At the sending unit for the oil light I put in a nipple, "T" nipple with a 45* and a liquid filled guage. The nipples I first used were steel and would leak at the block. Went with brass because of the heat esspansion difference with the block and steel nipple. Dont use a cheep guage, they have a plastic lens and will melt. Also with the "T" you still use the sending unit and still have your oil light.
Quick Reply: S&S oil pump & EVO
