Gas Gauge Removal
Gas Gauge Removal
I tried searching for this but no luck. I want to switch the gas caps on my 2010 FatBoy Lo with custom made ones from Leroy Thompson to match my floorboards and grips. They are sending me a pair for free to R&D them($130 each). I want to know if I can just unhook the gauge and screw on the new cap? Also how to unhook the gauge. I'm hoping that I can use the miles to empty feature on the speedo or will taking away the gauge screw that up? Thanks for any help.
If it is the same as the heritages the gauge is just pressed into the hole on the left side, a slow rocking motion while pulling up on it and it will pop out. The wires that go through the tank have a connector just below where the gauge is under the tank. It can be disconnected there but you will have to pull the pins out of the connector to feed the wires through to remove the gauge. The gauge function should not affect the speedo functions, to test that, go under the tank and unhook the fuel gauge connector and then take a ride around the block and see if the speedo readings are still what you expect.
When i removed my fuel guage, i had to twist it like 1/8th-1/16th of a turn counter-clockwise then it came right out.. and yeah.. there's a jack under the tank that you have to remove the pins from to get the wires to pull straight out. unless you plan on keeping the R&D'd guage then you can just cut the wires. though you'll be screwed later if you have to switch back.
