Substitute for Deutsch Terminal Crimp Tool? (HD-39965)
Old 04-17-2011, 09:49 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
Question Substitute for Deutsch Terminal Crimp Tool? (HD-39965)
Guys I have an upcoming one time need to use a Deutsch type crimp tool and was wondering in anyone has installed terminals without this or any other Deutsch type crimp tool.
I'll soon be installing the Tour Pak QD kit and the plug and play wiring harness (70032-09) and need to crimp some pins in place somewhere in the harness. Unfortunately the instructions don't specify where but I suspect it's the main jumper into the TP.
Any home remedies out there? You time is much appreciated.
Regards,
V2Evo96
Old 04-17-2011, 11:14 PM
clap's Avatar
clap
clap is offline
I have done it with small needle nose pliers. The crimp tool to much for my blood. I think it is a couple hundred bucks.
Old 04-17-2011, 11:31 PM
2nd Mike's Avatar
2nd Mike
2nd Mike is offline
Solder them on.
Tin the wire ends,heat the pins up with the iron,melt a little solder into the hole,then slide the tinned wire into the hole while still applying heat from the iron,wait a couple seconds,and your done.
Almost as fast as crimping and a much better connection.
user 8373900's Avatar
user 8373900
user 8373900 is offline
One of the special crimp tools can be had for about 50 bucks. Actually, I have had several chances to use it since, it's a nice addition to a tool box.
Mark
Old 04-17-2011, 11:50 PM
2black1s's Avatar
2black1s
2black1s is offline
Frye's Electronics - less than 20 bucks. I got one there designed for computer connector pins and it works perfectly.
But the solder recommendation is a good one.
I've done it both ways.
Old 04-17-2011, 11:53 PM
greg09997's Avatar
greg09997
greg09997 is offline
No need for the tool, just solder them and clip off the part that folds over.
Old 04-17-2011, 11:56 PM
Pc PaiN's Avatar
Pc PaiN
Pc PaiN is offline
Bought my crimp tool from Tool King. Has interchangeable dies that you can buy depending on your needs as well.
Old 04-18-2011, 01:21 AM
vzts4q's Avatar
vzts4q
vzts4q is offline
I use the same crimp tool that I have for GM weather pack connectors. Do a search for GM weather pack crimp tool. You can find them for around $35.00
Here is an example
http://cgi.ebay.com/ebaymotors/Delph...-/230589864160
A great addition to your toolbox.
Old 04-18-2011, 01:37 AM
Vins's Avatar
Vins
Vins is offline
Regards,
V2Evo96
Check this one out...
https://www.hdforums.com/forum/4277701-post1093.html
Old 04-18-2011, 05:00 AM
katobird's Avatar
katobird
katobird is offline
standard automotive ones are a good sub.
or needlenose..if you want some "extra protection" crimp it then hit it with a little solder
Quick Reply: Substitute for Deutsch Terminal Crimp Tool? (HD-39965)
