Old 03-17-2015, 12:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Harley Diagnostic Codes
http://www.hdforums.com/forum/igniti...tic-codes.html
Issue:
Road King is having issues and user has trouble finding diagnostic codes, so he decides to put together a list of common codes that are not easily findable.
Read below for full discussion…
Print Wikipost
Old 04-14-2011, 08:32 AM
skos's Avatar
skos
skos is offline
Default Harley Diagnostic Codes
My Road King had some sputtering issues and I had some codes
I could not find any info on codes here but saw a lot of people asking about them and have had no replies. My piece of crap dealership service manual does not have them so I did some research and came up with the following.
Can someone double check me to make sure this is correct?
To access codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" (on mine the “t” looks more like a “╘” )with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
1 - Record the codes.
2 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 3 If the code is current it will reappear.
4 – Press and release the odometer reset button to continue to the next module.
5 – Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1600 EFI Module Processor Internal Error
20. P1270 TGS Validation Error
21. P2107 EFI Module Processor Internal Fault
22. P2122 TGS1 Low/Open
23. P2123 TGS1 High
24. P2127 TGS2 Low/Open
25. P2128 TGS2 High
26. P2138 TGS Correlation Error (Twist grip sensor)
27. P0120 TPS1 Range Error
28. P0220 TPS2 Range Error
29. P0122 TPS1 Low
30. P0123 TPS2 High/Open
31. P0222 TPS2 Low
32. P0223 TPS2 High/Open
33. P2135 TPS Correlation Error
34. P2119 EFI Motor Throttle Body Range Performance
35. P2100 EFI Motor Circuit Open
36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
37. P2102 EFI Motor Circuit Low
38. P2103 EFI Motor Circuit High
39. P2176 EFI Closed Position Not Learned
40. P1514 Air Flow Fault
41. P2105 EFI Forced engine shutdown
42. P1501 Jiffy Stand Sensor Low
43. P1502 Jiffy Stand Sensor High
44. P0572 Brake Switch Low
45. P0117 ET Sensor Low
46. P0118 ET Sensor High
47. P0112I AT Voltage Low
48. P0113I AT Voltage Open/High
49. P1351 Front Ignition Coil Driver Open/Low
50. P1354 Rear Ignition Coil Driver Open/Low
51. P1352 Front Ignition Coil Driver High/Shorted
52. P1355 Rear Ignition Coil Driver High/Shorted
53. P1357 Front Cylinder Combustion Intermittent
54. P1358 Rear Cylinder Combustion Intermittent
55. P0261 Front Injector Open/Low
56. P0263 Rear Injector Open/Low
57. P0262 Front Injector High
58. P0264 Rear Injector High
59. P0562 Battery Voltage Low
60. P0563 Battery Voltage High
61. P0501 VSS Sensor Low
62. P0502 VSS Sensor High/Open..
63. P1356 Rear Cylinder No Combustion
64. P1353 Front Cylnder No Combustion
65. P0444 Purge Solenoid Open/Low
66. P0445 Purge Solenoid High
67. P1475 Exhaust Actuation Position Error
68. P1477 Exhaust Actuator Open/Low
69. P1478 Exhaust Actuator Shorted/High
70. P0131 Front Oxygen Sensor Low
71. P0151 Rear Oxygen Sensor Low
72. P0132 Front Oxygen Sensor High
73. P0152 Rear Oxygen Sensor High
74. P0134 Front Oxygen Sensor Inactive
75. P0154 Rear Oxygen Sensor Inactive
76. P1510 EFI Limited Performance Mode
77. P1511 EFI Power Management Mode
78. P1512 EFI Forced Idle Mode
79. P0577 Cruise Control Input High
1. U1300 Serial Data Low
2. U1301 Serial Data High
3. U1016 Loss of ECM Serial Data
4. U1255 Serial Data Error
5. B1142 Smart Security System Internal Fault
6. B1135 Accelerometer Failed
7. B1136(HFSM) Accelerometer Tip Test Error
8. B1151 Bank Angle Sensor(BAS) Short to Ground
9. B1152 Bank Angle Sensor(BAS) Short to Battery
10. B1153 Bank Angle Sensor(BAS) High
11. B1154 Clutch Switch Input Short to Ground
12. B1155 Neutral Switch Input Short to Battery
13. B1134 Starter Output High
14. B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
15. B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
16. B1123(HFSM) Left Turn Output Short to Ground
17. B1124(HFSM) Right Turn Output Short to Ground
18. B1125(HFSM) Left Turn Output Short to Battery
19. B1126(HFSM) Right Turn Output Short to Battery
20. B1143(HFSM) Security Antenna Short to Ground
21. B1144(HFSM) Security Antenna Short to Battery
22. B1145(HFSM) Security Antenna Open
23. B0563 Battery Voltage High
24. B1131(HFSM) Alarm Output Low
25. B1132(HFSM) Alarm Output High
26. B1141(TSM) Ignition Switch Low/Open..
B1141(HFSM) Ignition Switch Low/Open
The following 4 users liked this post by skos:
Bomber1955 (03-05-2017), peterjamesbenson (11-29-2017), silky1859 (06-28-2016), Siva pd (05-19-2020)
Old 05-06-2011, 01:49 AM
bigtony55's Avatar
bigtony55
bigtony55 is offline
Good info thanks
Old 06-03-2011, 03:54 PM
papifun's Avatar
papifun
papifun is offline
Anyone have the Code list for the 2011's 103 Power pak ? im tooling around with my PV and get 80:B2017
Old 06-25-2011, 09:43 PM
mmient's Avatar
mmient
mmient is offline
Thank you for helping me get back on the road after breaking down on the highway today! While waiting for the dreaded tow back home, I found this thread and was able to read the codes, fix the issue, and get back on my way!
The following 2 users liked this post by mmient:
LMCI-Enforcer (07-02-2019), MikeLaPlaya (02-25-2022)
Old 07-01-2011, 01:32 PM
jolayiv's Avatar
jolayiv
jolayiv is offline
Great post. It just helped me out too. Anyone know what to do about a P1009 Incorrect password code? I just recently installed my PCV (along with pipes and air cleaner) and have logged about 150 miles. Now on 3 straight start ups my check engine light has come on about 3 seconds after it goes out from starting and it stays on for about 5 seconds and then remains out.
Old 07-25-2011, 08:11 PM
Prowln's Avatar
Prowln
Prowln is offline
This is GREAT info! Although I went through the procedure as outlined above and had no codes to show up. My bike still coughs, sputters and almost dies at idle. I have put in new plugs, wires, air filter. Cleaned the throat / butterfly in the throttle body. If anyone has any suggestions which way to go next, it would be greatly appreciated. I have also ran 2 tanks with rocket fuel.
My bike is a 05 FLSTNI Deluxe.
Old 08-01-2011, 02:19 PM
hammr_hed's Avatar
hammr_hed
hammr_hed is offline
Default Code B2017
B2017 is 'Open Front Speaker'...if you have an amp installed, this is fine. I found this out last night while upgrading my radio software...
You should check your radio's software version, I'd assume it's up to date being you have an '11...but can't hurt. This is where you'll see the code as well.
turn radio to down all the way
turn off ignition
holding 1 and 2 buttons on radio turn switch to ignition and then to accessory
after the radio boots, you'll see a new series of menu items
press 4 for SOFTWARE
this is where you'll see your version v8.19 (8.25) is the latest version if you don't have that, then go to harley's webpage and search for radio software update (i used google and the first link was into HD's site for the download.
unzip the files to a directory you'll remember (i add a new folder to the desktop called HD)
burn those files (there are only 2 files) to a cd using a slow burn rate (they suggest 8 or lower)
do the same instructions to get into radio diag mode and hit 5 UPDATE...(make sure there is no CD in the radio before you do this)
once you hit 5 for UPDATE it will ask to insert CD...insert the disc with the two files on it you just burned...the system will take it from there. you can watch the steps...took about 5-10 minutes for mine.
if all it says is VERIFYING DSP IMAGE and doesn't change, you might have to burn at a slower rate...or use a different burning software.
when it's done the radio will come on...go into radio diag mode to be sure the v8.19 (8.25) software is there.
eject the disc and ride on!
Old 08-14-2011, 02:45 PM
WOS Bishop's Avatar
WOS Bishop
WOS Bishop is offline
I can't get the menu to come up. The only thing that keeps popping up is the letters "d01CLr" and if I press the reset button again the "01" changes to "02" and so forth up to the number "10" then "PPU" then "82883" which is not the miles on the bike.
Help!
Old 09-11-2011, 08:57 AM
stankie123's Avatar
stankie123
stankie123 is offline
Stage I
Default Error Code 82883
Help!
Have you found out what the code PPU 82883 meant? I am having the same issue and my bike shuts down after it gets warm! Anyone know what the problem can be?
Old 09-24-2011, 09:26 PM
Corsair's Avatar
Corsair
Corsair is offline
Default Picked this up on HDForums somewhere
The original poster said there is nothing wrong......
"After all the diagnostic codes are displayed, the speedometer's pulses per unit (PPU) setting is displayed. This number will vary depending on speedometer part number.
SPEEDOMETER TROUBLE CODES
CODE - TROUBLE - WIRE COLOR
d01 - speed sensor power output shorted low - red
d02 - speed sensor power output shorted high - red
d03 - not used
d04 - not used
d05 - speed sensor return shorted high - white
d06 - speed sensor return shorted low - white
d07 - not used
d08 - peedometer power overvoltage - orange/white
d09 - speed output shorted high - white/green
d10 - speed output shorted low or open - white/green
5 digit number - speedometer pulses per unit"
also "CLR means clear.
Again, not my answer, copied from elsewhere a while back as a reference.
Quick Reply: Harley Diagnostic Codes
