2001 Road glide EFI
Old 04-11-2011, 07:00 AM
FXRRider93's Avatar
FXRRider93
FXRRider93 is offline
Stage III
Default 2001 Road glide EFI
Morning all, I have a 2001 Road glide with the M.M. EFI and having problems. I pulled plugs when I first got the bike they were black (running rich). I bought the bike back in Dec so never really got to ride (Northeast lots of snow) I took it it out yesterday and found it to start right up idles fine, throttle lags when you twist seems flat. When riding you need to play with the throttle to keep from stalling when you takeoff from a stop, also popped back a few times, does not get better as engine gets hot. Air filter is the Screaming eagle and clean, has Screaming eagle slip ons. I just replaced the cam plate to the new style roller chains and installed new inner bearings and Andrews N21 cams( mild) I was planning on installing a Power Commander down the rode to fine tune but this rich issue was there before I did any work. Is there a way to check the engine and air intake temperature sensors, also any way to test the throttle positioner?
thank
Leo
Steve Jones Harley
11-14-2015 10:46 AM
sean400
10-15-2013 02:47 PM
sgwannabe
Exhaust System Topics
05-09-2013 07:52 PM
sgwannabe
05-01-2013 08:25 AM
leohd
Screamin Eagle CVO Models
08-11-2009 08:25 AM
Quick Reply: 2001 Road glide EFI
