Front Fender Rubber Grommet Replacement
Old 04-09-2011, 11:54 AM
01flhtc's Avatar
01flhtc
01flhtc is offline
Default Front Fender Rubber Grommet Replacement
What is the easiest way to replace the rubber grommet in the front fender of an FLHTC? This is the one that protects the electrical wire to the front fender lamp.
Old 04-09-2011, 06:33 PM
46u's Avatar
46u
46u is offline
The wires plug up in the fairing and most times you can get to them with out pulling the fairing off or at least I can on my 02 ultra. Just fallow the wires. Now the problem is the connectors will not fit through the hole in the fender. So I would just cut the wires a couple inches down from the connectors them pull the wires through the hole in the fender replace the rubber bushing then after putting the wires back through the rubber bushing butt splice the wires and put heat shrink over the but splices. My rubber bushing has been missing for about 60,000 miles with out a problem.
Old 04-11-2011, 03:37 PM
01flhtc's Avatar
01flhtc
01flhtc is offline
Thanks 46u. I found out how to do it. I unplugged it up under the fairing and then took dikes and cut the electrical socket off without touching the wires. This way, I bought a new socket, put the grommet in and the put the wires back in the new socket. No splice. Thanks man.
Old 04-11-2011, 03:39 PM
cromagnon's Avatar
cromagnon
cromagnon is offline
I tried slicing the new grommet with a razor then popping it in around the wire. Stayed in for a couple of days. Just said F' it after that.
SecondGear
2014-2023 Touring Models
03-31-2016 07:55 PM
just plain john
01-18-2015 10:34 AM
Roadrider18
12-31-2011 03:04 PM
Reaper_ggy
10-31-2011 08:55 PM
vegashd
03-27-2007 02:54 PM
Quick Reply: Front Fender Rubber Grommet Replacement
