Engine size from VIN
Old 04-03-2011, 05:43 PM
hogster1961's Avatar
hogster1961
hogster1961 is offline
Default Engine size from VIN
I am considering buying a 2007 Softail Standard from a private dealer in the UK, the bike has been imported from the U.S and is not a spec that we ever got over here...it's a 96" six speed(he says) with the 200 rear end, is there anywhere to check the motor size from the VIN number? Obviously I can check the six speed thing easily enough by going through the box and getting the '6' to illuminate in the speedo..the only evidence he can offer that it is definitely a 96" is the air cleaner cover script which I'm sure can easily be bought...he did let slip that before the bike arrived in the U.K he thought it was an 85" so was "pleasantly surprised to find otherwise", he seems straight enough and buys a lot of bikes but who knows?
Anyone know of a way to check?
Old 04-03-2011, 05:48 PM
HDs4me's Avatar
HDs4me
HDs4me is offline
Old 04-03-2011, 05:52 PM
ChromeJunkie's Avatar
ChromeJunkie
ChromeJunkie is offline
Received 3,802 Likes on 1,678 Posts
Harley changed all but the dyna's to the TC96 in 07, so it would be a 96, unless the engine was modified. I don't know if it is still the case, but the eighth digit in the VIN was the engine code back in the 80's.
Old 04-03-2011, 06:09 PM
SMF's Avatar
SMF
SMF is offline
Its on 07 its a 96
Old 04-03-2011, 06:18 PM
Dorkman's Avatar
Dorkman
Dorkman is offline
The 10th digit in the VIN should be a "7"...same as the third digit in the motor number...for a 2007.
Old 04-03-2011, 06:22 PM
aviator's Avatar
aviator
aviator is offline
2007 softail standards were built as 96 inch, 6 speed with a 200 rear tire.
Old 04-03-2011, 06:29 PM
perki48's Avatar
perki48
perki48 is offline
Received 4,101 Likes on 1,914 Posts
All '07's were 96 CI. Dynas got the six speed in 06.
Old 04-03-2011, 07:04 PM
ChromeJunkie
Well then, I stand corrected. I was thinking the Dyna's also got the 96 for the 06 model year.
Cbrwags
General Topics/Tech Tips
17
03-10-2023 07:41 PM
parrishbjj
Shovelhead
11
05-15-2014 07:44 PM
HDnoob
05-23-2013 06:32 AM
victoriouz
02-20-2010 11:17 AM
straydog13
Ironhead
03-22-2008 04:24 PM
Quick Reply: Engine size from VIN
