front fork axle nut torque
Old 04-01-2011, 06:24 PM
Flyer6440's Avatar
Flyer6440
Flyer6440 is offline
Default front fork axle nut torque
Do I have to measure the torque of this nut or just be sure it's tight. Also, the same with the pinch bolts holding the fork tubes. Thanks in advance
Old 04-01-2011, 07:20 PM
O-Town D's Avatar
O-Town D
O-Town D is offline
Originally Posted by Flyer6440
"Do I have to measure the torque of this nut or just be sure it's tight. Also, the same with the pinch bolts holding the fork tubes. Thanks in advance"
I think these would be considered "critical fasteners," and as such should be tightened to the correct torque value - others may disagree, but to each their own. You don't mention what bike you have, but on the '010 Dynas the front axle nut torque value is 62-67 FT-LBS, and the fork tube pinch bolts is 30-35 FT-LBS.
Old 04-01-2011, 10:03 PM
cmonster's Avatar
cmonster
cmonster is offline
same specs on my 08- just did it changing tire and fork oil-i dont worry too much about little stuff like belt guard bolts or horn bolts but pinch bolts and axel bolts very important!
Old 04-02-2011, 06:50 AM
Flyer6440's Avatar
Flyer6440
My bike is a 97 Super Glide. Are the torque values the same as yours?
Old 04-02-2011, 12:34 PM
O-Town D's Avatar
O-Town D
O-Town D is offline
"My bike is a 97 Super Glide. Are the torque values the same as yours?"
I would not think so - believe those earlier bikes had LOWER torque values on these particular fasteners. If you don't get an answer here in the Dyna forum, perhaps you can try posting in one of the other catagories for the factory torque specs on your year bike.
badbaggerz
07-28-2020 09:00 PM
blackduck889
09-13-2017 11:38 AM
MUTZ
05-19-2012 08:56 PM
slammed05fatty
04-04-2012 12:15 PM
al baehr
08-25-2009 04:52 PM
Quick Reply: front fork axle nut torque
