Help needed cant find relay
Old 03-20-2011, 12:54 PM
randy1352's Avatar
randy1352
randy1352 is offline
Default Help needed cant find relay
1999 ultra and cant find starter relay is it in location besides under side cover or under seat? Have book for a 2001 model it shows it in fuse block under side cover mine has fuses only no relay.Hope someone can give some help.
Old 03-20-2011, 01:44 PM
larsfum's Avatar
larsfum
larsfum is offline
I believe that it is under the fairing by the headlamp.
Old 03-20-2011, 01:48 PM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
Old 03-20-2011, 05:50 PM
randy1352's Avatar
randy1352
looked didnt see it
Old 03-23-2011, 10:40 AM
larsfum's Avatar
larsfum
larsfum is offline
Other place it may be is under the seat behind the battery.
Old 03-23-2011, 10:57 AM
Mike T's Avatar
Mike T
Mike T is offline
Are you referring to the starter "solenoid"? There shouldn't be a relay. The starter switch puts power to your solenoid and engages your starter drive. What kind of problems are you having?
Old 03-23-2011, 11:02 AM
inthechateau's Avatar
inthechateau
inthechateau is offline
Agree with MikeT, no relay. I have 99 Ultra same system. Esplain your issue and we can help. I'll look up in the tech manual when i get home tonight to help yo out if you still need it.
Old 03-23-2011, 08:02 PM
randy1352's Avatar
randy1352
got starter working but now no spark. I had tried to start with 10 amp battery charger hooked up but have no spark now
Old 03-23-2011, 09:27 PM
inthechateau
Is your battery voltage low? Using a jumper to get it to crank is not great idea. When you crank and voltage drops below 8vdc the ECU shuts down and will not allow trigget to ignition control module and will not crank angle sensor. Get voltage up or a new battery and see what you got. If you are having to jump with a good battery you have a bad ground on teh neg cable someplace on the frame. Grounds are very important on EFI systems.
Old 03-24-2011, 07:31 PM
randy1352's Avatar
randy1352
checked ground left battery tender on overnight til green light came on indicating fully charged battery
Quick Reply: Help needed cant find relay
