Difference between Stage 1 and Stage 2 download
Old 10-15-2006, 12:37 PM
baron3547's Avatar
baron3547
baron3547 is offline
Default Difference between Stage 1 and Stage 2 download
Hi,
Can someone tell me the difference between a Stage 1 and Stage 2 download?
Old 10-15-2006, 12:52 PM
dawg's Avatar
dawg
dawg is offline
Received 2,950 Likes on 1,709 Posts
Default RE: Difference between Stage 1 and Stage 2 download
One compensates for a Stage 1 setup (pipes and air) the other compensates for Stage 1 (big bore 95" and cams, etc.) Better to go with a PCIII, SERT, DFO, etc. instead of getting a download
Old 10-15-2006, 12:56 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
Stage I (Legal) - High Flow A/C unit and appropriate ECM flash.
Stage I (Race) - High flow A/C, Slip on SE Muffs, and ECM Flash.
Stage I (BB) - Big Bore, High Flow A/C, ECM Flash.
Stage II (BB) - Big Bore, Cams, High Flow A/C, Slip on muffs, ECM Flash.....
Old 10-15-2006, 01:10 PM
bountyhunter's Avatar
bountyhunter
bountyhunter is offline
ECM flashes are designed/intended for specified HD mods....PCIII is THE most popular/proven EFI tuning device on the market....for good reason....IT WORKS!
Old 10-15-2006, 02:04 PM
baron3547's Avatar
baron3547
I bought my RK Classic used. The bike has S&S 510 gears and a K&N Filter, it also came with Vance and Hines true duals with SE slip-ons. I put a Thunderheard 2 into 1 pipe and want to install a PC III but am not sure if the previous owner installed a Stage 1 or Stage 2 download. Can I use a PC III or do I have to use a SERT?
Old 10-15-2006, 02:15 PM
dawg's Avatar
dawg
dawg is offline
Can use either.
Old 10-15-2006, 02:17 PM
bountyhunter
PCIII and a precise dyno tune for that particular combo...it'll run strong!
Old 10-15-2006, 02:59 PM
baron3547's Avatar
baron3547
I thought about the SERT but it is to expensive for me right now. I am going to buy my PCIII from www.fuelmotousa.com. I don't know what I would do without this forum! Is there any other advice I need to know before I make my purchase? Thanks in advance!
Old 10-15-2006, 03:13 PM
Streetrunner's Avatar
Streetrunner
Streetrunner is offline
Here's the solution: go to the stealer and have them set your ECM back to stock. Get a PCIII from Fuel/Moto and speak with Jamie. I'm sure that's what he would recommend. That's what he told me to do.
http://fuelmotousa.com
Old 10-15-2006, 04:11 PM
Zack's Avatar
Zack
Zack is offline
How difficult is it to install a PCIII? Where does it go...is it attached somewhere?
Quick Reply: Difference between Stage 1 and Stage 2 download
