What would Cause Handle Bar shake?
Old 03-20-2011, 07:11 AM
Cheech2010FLHTK's Avatar
Cheech2010FLHTK
Cheech2010FLHTK is offline
Default What would Cause Handle Bar shake?
Went out for a ride yesterday afternoon. On the way home after an hour I took my hands off the bars and they started to shake almost violently. (quickly grabbed them to avoid wrecking) The bike only has 2600 miles. This was my first ride since last summer. I checked the tire pressure and it was fine. Has anyone else ever had a problem with front end shimmy?
On a side note when I warmed the bike up yesterday the handle bars themselves had alot more vibration then before. Any help or advise is appreciated.
Thanks,
Frank
Old 03-20-2011, 07:13 AM
cochon's Avatar
cochon
cochon is offline
Is it possible that the steering neck bearings need to be tightened up a little bit???
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
I would check the steering head bearing. How old is the bike? Sounds like it should still be under warranty.
Old 03-20-2011, 07:15 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Wow...2600m shouldn't be nearly enough for wheel bearing...?? Did you throw a weight?
Old 03-20-2011, 07:16 AM
Stiggy's Avatar
Stiggy
Stiggy is online now
Received 5,553 Likes on 3,058 Posts
Could also be a bad tire
Old 03-20-2011, 07:17 AM
NewAge's Avatar
NewAge
NewAge is offline
Yeah, go get the front wheel re-balanced. You threw a weight. Its not uncommon. Easy fix - don't stress.
Old 03-20-2011, 07:25 AM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
I wouldnt think throwing a weight would affect the shake at idle.
Old 03-20-2011, 07:34 AM
SixSixRider's Avatar
SixSixRider
SixSixRider is offline
This has come up before and generally seems to be related to preload on the neck bearing:
https://www.hdforums.com/forum/touri...nd-wobble.html
As noted in this other thread, there's an HD service bulletin on the subject. My '09 Road Glide has the same issue and I have yet to deal with, so I keep my hands on the grips.
Old 03-20-2011, 07:38 AM
bagga's Avatar
bagga
bagga is offline
it could be loose rear spokes......if you have spokes.
Old 03-20-2011, 09:59 AM
Cheech2010FLHTK
Thanks guys.
I have some searching and reading to do. Seems I am not the only one with this problem. Need to do a better search next time I have a question. found 2 pages of similar posts.
But thanks for pointing me in the right direction
Quick Reply: What would Cause Handle Bar shake?
