volt meter reading high?
Old 03-17-2011, 07:12 PM
shagnasty's Avatar
shagnasty
shagnasty is offline
Default volt meter reading high?
New 2011 Streetglide, voltage gauge reading 14-14.5 ish all the time. Is this normal?
Old 03-17-2011, 07:14 PM
lp's Avatar
lp
lp is online now
Received 2,722 Likes on 1,547 Posts
I think so. Mine does the same and there is no way it is broke because like me, my bike is perfect!
lp
Old 03-17-2011, 07:15 PM
themensh's Avatar
themensh
themensh is offline
Mine does also. Put a volt meter accross the battery and at 2000 RPM, it read 13.9
I figure that is good enough (2004 FLHTCUI)
Old 03-17-2011, 07:25 PM
shagnasty's Avatar
shagnasty
Thanks! I just wanted to be sure.
Old 03-17-2011, 07:35 PM
bronxbill's Avatar
bronxbill
bronxbill is offline
Normal
Old 03-17-2011, 09:10 PM
papifun's Avatar
papifun
papifun is offline
normal - had same question when i got my 2008.. voltmeter and true voltage while bike is running has some error.. i guess about 5-7%... User Manual scared me when it says should no read higher then 14V... thats what brought on the question to dealer..
Old 03-17-2011, 11:55 PM
JohnScrip's Avatar
JohnScrip
JohnScrip is offline
Noticed it yesterday on mine also. My '08 ran just below 14. This one is much closer to 15. But if it's as accurate as the fuel gauge, I'm not really worried...
Old 03-18-2011, 12:09 AM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 21,922 Likes on 8,433 Posts
I don't think the meters in the fairing are precision calibrated instruments so there will be variances high or low of the actual voltage. Using a calibrated VOM at the battery will give a much better reading.
Old 03-18-2011, 01:09 AM
VTGlideRider's Avatar
VTGlideRider
VTGlideRider is offline
Mine runs right there also, never had a problem. 2010 EG classic
Old 03-18-2011, 04:27 AM
Rooster37's Avatar
Rooster37
Rooster37 is offline
Heck mine reads 15+ every time. I worry if it drops below that. I tend to agree that the gauge is not terribly accurate.
Quick Reply: volt meter reading high?
