Cleaning up solenoid terminals
Old 03-15-2011, 08:49 AM
47Norton's Avatar
47Norton
47Norton is offline
Default Cleaning up solenoid terminals
Yesterday I cleaned all the battery cables and tried to clean the solenoid terminals. The upper one (battery) was easy to access, the lower one (motor) is in very tight quarters. Does the solenoid have to be removed to access this post for cleaning. Not sure it needs it as the starter seems to be working fine now that I removed some corrosion at the post on the solenoid. I would just like to go ahead and clean everything while I'm into it. Anyone done this particular service? TIA, Roy
Old 03-15-2011, 09:01 AM
Mike T's Avatar
Mike T
Mike T is offline
First, remove your ground cable on the battery, you don't want the motor turning over when you do this, it'll make you hurt yourself getting your hand out of there. Remove the three screws on the solenoid cover and the cover itself. Pull the plunger out. Take a file and clean the corrosion from the brass end of the plunger and reinstall.
Old 03-15-2011, 10:07 AM
47Norton's Avatar
47Norton
47Norton is offline
Mike, Thanks for the reply and I will pull the plunger out and clean it, too. What I also want to do is clean the outside terminal that is sort of underneath the solenoid. Were you able to remove that lower cable with the solenoid in place?
Old 03-15-2011, 10:13 AM
Mike T's Avatar
Mike T
Mike T is offline
You'd probably have to remove the starter to do that and that involves the primary cover too. Clean that plunger and you should be in good shape.
Old 03-15-2011, 10:24 AM
47Norton's Avatar
47Norton
47Norton is offline
I'm on it. Thanks again Mike.
Dorf
09-16-2013 10:48 AM
teeboz
09-04-2013 01:50 AM
dochawken
Electrical/Lighting/Alarm
11-23-2011 09:20 AM
mpc6.0
Exhaust System Topics
04-07-2009 09:31 PM
ettev
07-21-2007 06:02 PM
Quick Reply: Cleaning up solenoid terminals
