Need to change starter advice.
Old 03-09-2011, 10:58 AM
RKLeo's Avatar
RKLeo
RKLeo is offline
Default Need to change starter advice.
Looks like I need a starter. Twice in the last week I had to tap on mine with a wrench to get her to turn over. Before I order the starter, is there any other parts required? Gaskets? Anything?
I never had to change the starter so I am going in blind.
Any advice would be a huge help. Anyone know how long this job takes?
THANKS!
Old 03-09-2011, 11:35 AM
rounder's Avatar
rounder
rounder is offline
gotta take the primary cover off. so primary cover gasket. Takes about a 1/2 hour or so.
Old 03-09-2011, 12:36 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
Originally Posted by TIDE
Looks like I need a starter...Before I order the starter, is there any other parts required? Gaskets? Anything?
Any advice would be a huge help...
Parts and service manuals. There's no need to go in blind.
Old 03-09-2011, 01:19 PM
RKLeo's Avatar
RKLeo
RKLeo is offline
Thanks so far,
I didnt know about the primary cover!
I do have a service manual, lots of tools, and a j+s jack. I should be good. I am at work and havent looked at the manual yet. I just need to beat on the starter so I can get home. I found a great price on a starter, but didnt want to order it without checking in here first.
THANKS!
Old 03-09-2011, 01:33 PM
Mike T's Avatar
Mike T
Mike T is offline
Thanks so far,
THANKS!
When you get home and the bike cools down, disconnect the negative cable on the battery and try this. Take the solenoid cover off the starter with the bike on the kickstand. There's a plunger in there, pull it out. Look at the brass face of that plunger and see if there's any corrosion on it. If it is, take a file and clean it up. Reinstall and see if this helped. That could be the only thing wrong with it.
Old 03-09-2011, 01:36 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
+1 also check the electrical connections. Any corrosion inside or out can have the same symptom. Oh yeah. make SURE you take the neg cable off the battery....that bitch will try to start while you are working on it and absolutely scare the f**k out of you. Don't ask how I know this.
Old 03-09-2011, 03:07 PM
RKLeo's Avatar
RKLeo
RKLeo is offline
Excellent Advice!!! Will do.
This might be the case since its very inconsistant. I just went outside to try to start it and she fired right up.
Thanks
Old 03-09-2011, 03:31 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
Default beat on it
...I just need to beat on the starter so I can get home...
Around 30 years ago I was travelling in British Columbia w/ my old Dodge truck, towing a little 18' Airstream trailer. Many miles past nowhere, my starter went out. Along came a couple of friendly Canadians in a pickup. When I told them what happened, one fetched a hammer from his truck, slid under mine, and gave my starter a few good solid whacks. I thought to myself: WTF? He said: "OK, try to start it." Of course, it started immediately!!! I saw that a bunch of brass-colored filings had fallen to the ground directly under the starter. W/o shutting it off, I found a used starter @ a wrecking yard, and was on my way, once more. Thanks to some resourceful Canadians.
Anyway, the trick will never be forgotten.
Old 03-09-2011, 07:18 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,299 Likes on 2,353 Posts
+1 on the starter solenoid.And make sure you disconnect the battery!
Rusty Axle
Shovelhead
03-14-2018 02:18 PM
USMAMule
06-18-2017 09:36 PM
DieselJoe
03-12-2015 09:56 AM
BigTone24
EVO
07-02-2011 12:00 AM
porkchop59
08-08-2006 01:21 PM
Quick Reply: Need to change starter advice.
