Headlight adjustment WTF!!!!!!!!!!!
Old 03-08-2011, 07:33 PM
scasey's Avatar
scasey
scasey is offline
Angry Headlight adjustment WTF!!!!!!!!!!!
you would think to be easy, NOT! Can't even budge the bolt it is so f'ing tight...... speaking of tight there is no room to get in there to get a socket on it as far as i can see without risking the dropping of the socket onto the front fender. WTF is just a simple job so GD complicated because of a ridiculously stupid design.
Venting and pi**d off at such a stupid thing that should be simple. Why the He** is it even set up that way??
Old 03-08-2011, 07:35 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Sometimes you can move the headlight without loosening the bolt. Ask how I know. Just grab the headlight bucket and push down or pull up on it. My bolt for the adjustment is unmovable as well.
Drew
Old 03-08-2011, 07:38 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
If all else fails, get a bigger hammer.
Old 03-08-2011, 08:58 PM
watchluvr4ever's Avatar
watchluvr4ever
watchluvr4ever is offline
I had to use a 1/2" socket wrench to get mine loose.
Old 03-08-2011, 09:03 PM
Jeff W's Avatar
Jeff W
Jeff W is offline
Throw thick towel over fender and tank as well to be safe.
Old 03-08-2011, 09:08 PM
fcsallan's Avatar
fcsallan
fcsallan is offline
The worst part is trying to get it tight enough that the bucket won't move after you get it where you want it without moving it yet again. I would try to adjust without messing with that FU$%^&G bolt.
Old 03-08-2011, 11:47 PM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
I assume you are talking about the side-mounted vertical adjustment bolt? If so, mine must have been installled by the same gorilla that put yours on. I finally gave up and tried a different approach. I removed the bolt that secures the headlight block to the tree and removed it with the headlight attached. That gave me enough room to put a socket and electric impact driver on, and it came off instantly. I replaced it with a chrome allen and nylock. Problem solved.
Old 03-08-2011, 11:53 PM
SMF's Avatar
SMF
SMF is offline
Yea mine was a pita also but not as bad *** pulling an oil cooler from a sh-60 hahahaha
Old 03-09-2011, 06:41 AM
scasey's Avatar
scasey
scasey is offline
going to try this aproch later tonight, we'll see!
Old 03-09-2011, 07:52 AM
watchluvr4ever
I had my tank off when I loosened mine but that's because I was taking the front end apart. I could see it being more difficult with the tank on.
vTwinCityScramble
11-15-2017 09:42 PM
zigzag
09-13-2017 03:11 PM
gant
05-08-2013 07:56 PM
Voony
12-09-2011 12:12 PM
wd_cochran
07-19-2009 03:35 PM
Quick Reply: Headlight adjustment WTF!!!!!!!!!!!
