How to replace shocks?
Old 03-06-2011, 08:18 PM
doitinthewoods's Avatar
doitinthewoods
doitinthewoods is offline
Default How to replace shocks?
Can someone giva a step by step on how to replace shocks on an 08 wide glide? thanks
Old 03-06-2011, 08:43 PM
h8ter's Avatar
h8ter
h8ter is offline
Support your bike on either a center stand/lift or 4x4s. You'll need to get the bike off the ground enough so the rear tire is not touching.
Support the rear tire with a shim of some sort (a 2x4 will work).
Unbolt top and bottom of shocks. They won't just come flying off. Remove shocks. You may need to raise or lower the rear tire by hand to get them off.
Your swing arm will now move freely, so be careful.
Put new shocks on. You'll need to move the tire up or down to align the swing arm mounting points with the shock eyes.
Bolt down both top and bottom. Remove shim from under rear tire. Lower bike. Make sure nothing is scraping, binding, etc.
Old 03-06-2011, 08:52 PM
red devil's Avatar
red devil
red devil is offline
Simple job, just raise the bike with a lift just enough to take the load off the shocks(rear tire will barely be touching the ground). If your doing the same length shocks then do one at a time...off with the old on with the new. But if your going to a shorter shock you can take both off at the same time, then lower the jack just enough to be able to get the shorter ones back on.
Old 03-06-2011, 09:23 PM
doitinthewoods
Thanks guy's. got it.
Live2rideUtah's Avatar
Live2rideUtah
Live2rideUtah is offline
make sureyou use the correct locktite and the specs for the torque, don't want anything to happen on the back end. Very easy mod to do.
Old 03-06-2011, 09:24 PM
jshull's Avatar
jshull
jshull is offline
i take it your shocks got there!
Old 03-06-2011, 09:43 PM
yandeltx's Avatar
yandeltx
yandeltx is offline
Is the top a bolt, requiring a back up wrench, or is it a stud that doesn't require a backup?
Old 03-06-2011, 10:03 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
Struts are threaded, you can just go after the nut/bolt on the outside.
Old 03-06-2011, 10:09 PM
doitinthewoods
no, shocks not here yet I live on the very top of Maine I'm sure a few day's from now, can't wait.
Old 03-06-2011, 10:27 PM
streetg7's Avatar
streetg7
streetg7 is offline
Not trying to hyjack thread...what if shocks are longer? Putting 13s on a SG. Thanks
Stroked sportster
03-26-2016 03:08 AM
skiddd
09-05-2014 02:54 PM
bzgal
04-05-2010 03:16 PM
trelfster
11-21-2009 03:58 PM
jimmything
11-09-2008 09:22 AM
Quick Reply: How to replace shocks?
