98 fatboy rear wheel problem
Old 02-27-2011, 09:17 PM
cmitch38's Avatar
cmitch38
cmitch38 is offline
Stage III
Default 98 fatboy rear wheel problem
Hello, i just had new tires done for my 98 fatboy. The front wheel went back on with no problems, but the back wheel did not. I put it on and took it for a test ride, i noticed it was rubbing the belt guard, so i put it back up on the jack. Thats when i realized that the spacer on the left side (the bigger spacer) could slide back and fourth for about a half inch. I have no idea why, other than maybe a bearing fell out and i didnt see it. Does anybody know what the problem is? I'm going to have to buy a service manual to figure it out i guess, but i thought i would post it here to see what yall think. Thanks.
Old 02-27-2011, 11:46 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
The longer spacer does go on the left, but something is definitely wrong. Did you put the right side spacer back on?
Drew
Old 02-28-2011, 01:54 AM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
yeah what drew said! did you put the narrower right side spacer on?? and both bearings in??
shouldnt be a prob??pretty strange, wouldnt think the bearing would just fall out?
Old 02-28-2011, 06:26 AM
handyhoward's Avatar
handyhoward
handyhoward is offline
From the right side the axle goes thru the swing-arm first... then the rear brake arm... then the smaller of the two spacers... then the wheel... other side spacer (larger of the two)... then the left side swing-arm. If it's not right it won't tighten up snug.
Old 02-28-2011, 04:13 PM
osrblack's Avatar
osrblack
osrblack is offline
I know I took off my back wheel on my 97 fatboy and I had three spacers I think one on the break side and two on the belt side. I will check for sure when I get home.
Old 02-28-2011, 04:50 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,499 Likes on 4,612 Posts
There is a small spacer on each side, that go into the grease seals. Sometimes guys forget to pull them out when they bring a wheel in to have the tire changed.
Sounds like one of the small spacers stayed with the wheel when you brought it in for the tire change, and somewhere along the way it came out. The small spacers are about 3/4" long.
There is also a longer spacer, it goes outboard of the small spacer, on the left side.
Trace back your footsteps, you will find that spacer, in garage, trunk of car/truck, or maybe the shop yanked it out and forgot to get it back to you.
Note: To be on the safe side, you should remove the wheel, and pop out the grease seals and bearings and inspect the bearings to make sure they did not get damaged from running without the spacer. If you didn`t re-pack the bearings with grease, now is the time, front ones too...
I repack both front and rear wheel bearings every time I change a rear tire, still have the original bearings in my `89, with 135,000 miles on them.
Old 02-28-2011, 07:06 PM
osrblack's Avatar
osrblack
osrblack is offline
that is what i just found as well on my bike as well. Good luck on your search...
Old 02-28-2011, 11:07 PM
cmitch38's Avatar
cmitch38
cmitch38 is offline
Stage III
thanks guys. i do not have a small spacer on the left side. the one on the right side is still there and the big one on the left side is there, but no other spacer. i'll ask the shop if they have it because i dont see it around my work area. thanks everyone.
Unsung
Wheels/Tires
03-28-2017 04:53 PM
Stricnine
Wheels/Tires
08-29-2014 08:26 AM
gtrplyr
03-18-2012 08:22 PM
harley7316
EVO
07-23-2011 11:36 AM
smudge
10-04-2007 07:31 AM
Quick Reply: 98 fatboy rear wheel problem
