fork seal installation...?
Old 02-24-2011, 06:47 AM
Ridin'withTheKing's Avatar
Ridin'withTheKing
Ridin'withTheKing is offline
Default fork seal installation...?
I have sent my fork lowers out to have them powdercoated, and should have them back soon. My question is this... How hard/technical is it to install the new bushings and seals in the lowers? I would like to do it myself, but not if I am going to have to do it more than once or twice (if I screw it up). The cost of a seal install tool is way cheaper than having a stealer do it, but again, only if I get it right the first time. Any sugestions, comments? Also, of those of you that do this yourself, what seal installing tool do you recommend?
Thanks for any responses....
Old 02-24-2011, 07:09 AM
rg_dave's Avatar
rg_dave
rg_dave is offline
Lots of threads on this. The PVC tool works great. A friend of mine made me one using a stepdown connector the size of the metal ring that goes with the seal its a 2 x 1 1/2 and 1 1/4 piece. We then use about a 18"x 2" piece of pipe as a slide hammer.
Old 02-24-2011, 07:18 AM
SCJE8's Avatar
SCJE8
SCJE8 is offline
It's a pretty simple job...especially since you have everything apart for the powdercoating. The fork seal tool is a great investment and leaves very little room for error if you may be doing the job again for your own ride or someone elses bike. But if you are only going to use it just this one time you may want to pass. Like SG_Dave said...the PVC pipe route works very well.
Good luck...
Steve
Old 02-24-2011, 07:25 AM
veegee's Avatar
veegee
veegee is offline
I just did my front forks on a Dyna and used the tubes as a slide hammer to remove the old seals and the old seals to help set the new ones.
Old 02-24-2011, 07:43 AM
bellgnte's Avatar
bellgnte
bellgnte is offline
As everyone else said, get a seal driver (or PVC model). Just set the big flat washer first and then the seal. Install the retaining ring and your done.
Old 02-24-2011, 10:06 AM
Ridin'withTheKing
ok. sounds good. I think I'll order up the seal tool, as I'll probably get my gal a chrome set of legs for her scooter too. I can practice on my ride, so she can't b**** me out for experimenting on her ride.
Old 02-25-2011, 08:56 AM
ElectraHead's Avatar
ElectraHead
ElectraHead is offline
Does anyone have a pic of this home made pvc seal installation tool. I am pullin mine apart tonight and would like to save the money and make my own tool.
thanks in advance
Old 02-25-2011, 11:28 AM
Ridin'withTheKing
I'd like to see a picture of this too.
Thanks!
thanks in advance
Old 02-25-2011, 05:29 PM
69cj's Avatar
69cj
69cj is offline
I too would like to see it. Thanks in advance, Mike
Old 02-25-2011, 06:02 PM
im's Avatar
im
im is offline
For the PVC home tool:
Consider taking your new replacement seals to LOWES, HOME DEPOT, ACE or whatever hardware store you have local.
#1 Look at the boxes with the various white plumbing PVC connectors
#2 look for one that just fits the seal..not bigger but just fits it.
#3 If your working on a bike that the tubes are not coming off for installation then the PVC piece must be cut in half vertically.
Quick Reply: fork seal installation...?
