Dyna Super Glide Custom Sissy Bar Install
Old 02-12-2011, 06:21 PM
artpe54's Avatar
artpe54
artpe54 is offline
Default Dyna Super Glide Custom Sissy Bar Install
I need some advice/help, I tired to install a rigid mount sissy bar on my FXDC today. When I tried to remove the bolt that holds the turn signal it will not come out as it hits the tire. Maybe I'm missing something and I;m just tired. I installed a D&D Fat Cat exhaust today too. Any assistance or help would be greatly appreciated. By the way it's q 2010.
Old 02-12-2011, 06:41 PM
SteveO-ll's Avatar
SteveO-ll
SteveO-ll is offline
Jack the bike up, so the back tire drops down some........either that or disconnect the shocks to let the swing arm swing down until you have clearance.
Old 02-12-2011, 06:52 PM
artpe54's Avatar
artpe54
artpe54 is offline
I thought of both of those, only problem is I don't have a jack. If I can't come up with anything else I'll try dropping the shocks. Thanks.
Old 02-12-2011, 07:03 PM
bberck's Avatar
bberck
bberck is offline
You can try letting the air out of the tire, that may give you enough clearance
Old 02-12-2011, 07:06 PM
bobnehoc's Avatar
bobnehoc
bobnehoc is offline
If you have a scissor jack from a car that will work. Just place towards the rear of the frame and use a block of wood to protect the frame. I had to do that once before I had my bike jack. You will only need to raise it up a little bit to get the bolts to clear the tire...I know because I had the same problem when I was putting my docking kit on my bike......
Old 02-12-2011, 07:13 PM
thumperhdcmc's Avatar
thumperhdcmc
thumperhdcmc is offline
are you using a socket and rachet? a racheting combination wrench might do the trick
Old 02-13-2011, 04:02 AM
artpe54's Avatar
artpe54
artpe54 is offline
Thanks for all the input. I tried letting air out of the tire, that didn't help either. My jack is back at my cabin in Ohio.. Just might have to wait until I travel there in Feb and bring it back.
Old 02-13-2011, 09:46 AM
gump305's Avatar
gump305
gump305 is offline
Install a solid mount sissy bar on my 2011, had to use a jack and alittle elbow grease, finally got it on. Be careful and take your time so you don't scratch you fender.
Old 09-16-2013, 08:45 AM
MorrisGray's Avatar
MorrisGray
MorrisGray is offline
What do you use to keep from scratching your fender?
Black rubber washers or what?
Old 09-16-2013, 09:27 AM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
I use blue painters tape.
Quick Reply: Dyna Super Glide Custom Sissy Bar Install
