103 Performance Mods
Old 02-08-2011, 01:13 PM
Fuji's Avatar
Fuji
Fuji is offline
Default 103 Performance Mods
Have a 2010 RK 103 Police with Rush slip ons.
Looking to boost performance (aren't we all?). Figuring some cams, power pack and air cleaner are cheap ($1500) boost. But will do more if there's better bang for buck.
Don't want to re-invent the wheel.
What has worked for you?
Thanks
Old 02-08-2011, 01:20 PM
equandt's Avatar
equandt
equandt is offline
You had better check the Fuel Moto 107" kit. Big power for sure.
Old 02-08-2011, 01:35 PM
Tek74's Avatar
Tek74
Tek74 is offline
I would definately consider a FM-107 kit if upgrading from a 96, but not so much from a 103. I guess that 4 extra ci is just not enough for me to go that route. I say just do a Stage 2. You already have slipons, so pick up some good headers and cams. The wood cams seem to be one of the best.
Old 02-08-2011, 01:44 PM
07FLHT's Avatar
07FLHT
07FLHT is offline
Good set of head pipes, cams, tuner, maybe a little head work if you like, and your set!
Old 02-08-2011, 02:24 PM
mphamrick's Avatar
mphamrick
mphamrick is offline
Well a lot depends on what you plan on doing and what rpm's you ride at. You can see what I have done and the dyno results for my bike below the pic. I ride in the 2500 to 2700 rpm range that is where I needed that extra kick in the pants if needed. I am all about the torque don't need those high horsepower numbers.
Old 02-08-2011, 03:46 PM
iclick's Avatar
iclick
iclick is offline
Some nice bang-for-the-buck options:
1. Slightly used 255 cams bought on Ebay: $200-300 total if you DIY. Wood 555 or SE204 cams would also do well in your 103 with its standard 9.6:1 compression. Add $150 (SE) to $250 (Wood) for new cams.
2. Fuel Moto Power Package (PCV and AC) minus the mufflers: ~$400 (IIRC). Buy the Jackpot Dyno-Tuned baffles (~$100) for your Rush mufflers for a nice all-round power boost.
3. Head-pipe upgrade to get rid of the cat, if your bike has one. Fuel Moto makes one and sells other brands, too.
Dixiemilker
Engine Mechanical Topics
11
04-08-2015 08:00 PM
EasTexUltra12
03-27-2014 08:27 PM
JimTJr
01-29-2013 09:02 PM
k9t8m
11-30-2012 08:58 PM
patriotmc
11-07-2009 09:12 PM
Quick Reply: 103 Performance Mods
