2000 FXDX diagnostic trouble codes
Old 02-08-2011, 05:14 AM
rev777's Avatar
rev777
rev777 is offline
1st Gear
Default 2000 FXDX diagnostic trouble codes
I have a 2000 FXDX that we have just fitted an S&S T111 engine in (carburettored).
The ECM is the S&S IST unit that comes with the engine.
OK this is what happens
- Turn on ignition
- ENGINE lights in red
- ENGINE light goes out
- ENGINE light comes on again and then goes off
If I start the bike it will run for about half a minute and then it seems to lose power and the ENGINE light comes on again.
I tried the diagnostic trouble codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button.
The odometer shows d01CLr (presumably meaning diagnostic #1 clear)
press odometer reset button - now shows d02SEt (does that mean that diagnostic #2 is set?)
pressing the odometer reset button then displays d03CLr, d04CLr, d05CLr, d06CLr, d07CLr, d08CLr, d09CLr
the next press after that displays CAL 10 (whatever that means)
pressing it again starts the sequence again
What do these codes mean?
Old 02-08-2011, 05:18 AM
rev777's Avatar
rev777
rev777 is offline
1st Gear
Sorry title should be 2000 FXDX diagnostic trouble codes
Old 02-08-2011, 06:49 AM
mud's Avatar
mud
mud is online now
muderator
Received 8,738 Likes on 2,059 Posts
might be easiest to call S & S.
dirtracer27x
08-24-2014 02:12 AM
risdo
09-29-2013 09:15 AM
tingland
07-15-2012 03:42 PM
rev777
02-03-2011 03:59 PM
zaraghjr
08-02-2010 11:58 PM
Quick Reply: 2000 FXDX diagnostic trouble codes
