Best Motor Oil
Old 02-05-2011, 12:58 PM
CobraEd's Avatar
CobraEd
CobraEd is offline
Default Best Motor Oil
Check out this article. Most all of the oils test out the same until you scroll all the way down to the bottom of the list. I knew that Royal Purple oil was terriffic stuff from other info I have read, but look at the results here. Huge difference!!! They make a 20 - 50 motorcycle oil that is all I use in my Dyna.
http://www.animegame.com/cars/Oil%20Tests.pdf
Old 02-05-2011, 01:30 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
100% total bullshit
Old 02-05-2011, 01:40 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
Originally Posted by KBFXDLI
100% total bullshit
Why is that? I was thinking Red Line or Royal Purple this time to replace the (now I shudder) Syn3 in the scoot. Now I'm leaning toward Purple...
Scratch that...I just bought a case of Amzoil.
Old 02-05-2011, 01:42 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
I would think that a proper test would have used all the same viscosity oil. This test includes oils, from as low as 0 x 40 to 15 x 50 .
Old 02-05-2011, 01:48 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
2 reasons.
1. The Timken bearing test machine is made for testing gear oils on tapered roller bearings used in transmissions. No correlation with internal combustion engine test conditions or data.
2. The oils in the tests are automotive (water cooled) engine oils. Not air cooled loose tolerance Vtwin engines.
So, if you plan on using a 5w40 or 10w40 engine oil in your Harley transmission then some of this test data may be close. Otherwise it is crap.
Also, not sure there are any tapered roller bearings in a Harley Davidson...might be in the trans but I doubt it.
Old 02-05-2011, 01:49 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Yeah, that would be another minor detail.....
Old 02-05-2011, 01:50 PM
Mal74's Avatar
Mal74
Mal74 is offline
Damn, 7 posts and he's an oil expert!!! Does the OP work for Royal Purple?
The article may not be 100% BS, but it's at least 99.9% BS. What oil we use is mostly personal preference. As long as you use quality oil and change it regularly you won't have any oil related problems.
Old 02-05-2011, 01:52 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Exactly! As long as it meets the Harley API specs in your owners manual.
Old 02-05-2011, 01:56 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
2 reasons.
This is the part that intrigues me. This is undoubtedly representing HD Dino Oil, Syn3, and their product. Admittedly, I am NO oil expert. However, I certainly have yet to hear a solitary bad thing about Royal Purple.
Max-Cycle is specifically formulated to significantly improve motorcycle, ATV and snowmobile engine (and transmission) performance. It’s recommended for use in both air-cooled and liquid-cooled 4-cycle engines and it’s compatible with wet-clutch transmissions.
Max-Cycle’s high film strength dramatically reduces wear. Take a look at the pictures of cam chain tensioners below.
Each tensioner came from an American V-Twin engine with 10,000 miles of use. The tensioner on the left is from an engine that used the manufacturer’s conventional oil. The tensioner in the middle is from an engine that used the manufacturer’s synthetic oil. The tensioner on the right is from an engine that used Royal Purple after an initial break-in period of 1,500 miles. Once again, all of the cam chain tensioners are shown after a total of 10,000 miles of use. The difference in wear is dramatic.
Old 02-05-2011, 01:58 PM
BBStacker's Avatar
BBStacker
BBStacker is offline
I prefer to use canola oil much better health wise.
Quick Reply: Best Motor Oil
