Gear Reduction Options on FL
Old 01-29-2011, 11:40 AM
jlturner's Avatar
jlturner
jlturner is offline
Red face Gear Reduction Options on FL
I have a 2009 Street Glide. Wanted to change the stock overall gear ratio which is my understanding @ 2.89. My understanding to do this is I have two options:
Change the primary trans gear sprocket down from 32 to 30T
Or
Change the front belt drive pullet from 32 to 30T
My questions are:
  • What are the pros or cons of each option?
  • Would I get the same result doing either option?
Old 04-09-2011, 11:47 AM
jejean's Avatar
jejean
jejean is offline
Stage I
Called Baker trans & talk to Mark. looking for same on 2010.. watch out for drive pulley, changes speedometer??
Old 04-09-2011, 01:34 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Or
My questions are:
Your options are: Change engine primary sprocket from 34 to a 30 sprocket(losing the compensator in the swap), change clutch primary sprocket from 46 to 49, change trans pulley from a 32 to a 31 or a 30 OR spend over 3 grand utilizing a Baker DD7 gearset.
Old 04-12-2011, 07:33 AM
grbrown's Avatar
grbrown
grbrown is offline
My reading of this is there is a further option, of fitting a 68T rear pulley. Personally I would leave the primary gearing alone, as changing the clutch sprocket is a silly price and ditching the compensator doesn't seem wise!
If you go to 30/68 belt drive your overall will change to 3.07:1 and top gear will change from approx 27mph/1,000rpm to 24.5mph/1,000rpm. From what I can make out the stock belt will still fit when changing both pulleys.
There is more on this over in the Touring forum. Just search that forum for '68T'.
Old 04-12-2011, 09:37 AM
qtrracer's Avatar
qtrracer
qtrracer is offline
He already has the rear 68T pulley from the factory, it's an 09. And he can swap to a chain final drive keeping the IDS, good choice for those who have had belt breakage issues.
Old 04-12-2011, 10:06 AM
grbrown's Avatar
grbrown
grbrown is offline
Red face
Oops! Should have checked my facts!
Old 04-14-2011, 10:13 AM
lkr0's Avatar
lkr0
lkr0 is offline
I have been looking for a chain drive my 09 -- some say an 08 chain conversion will work; does anyone know of any other options?
Nitrusfix
01-22-2016 06:23 AM
olongapo1
05-13-2014 09:52 PM
shrugger
09-06-2009 04:57 PM
rmc115
02-23-2009 06:04 AM
Vettepro
03-23-2008 08:36 PM
Quick Reply: Gear Reduction Options on FL
