Idle adjustment
The idle screw is on the right side of the carburator, just behind the air cleaner.
It is in the upper right portion of this photo (zinc plated, looks like brass). The screw phyisically moves the idle pulley (holds the throttle and idle cables) to adjust the fuel mix. Once you find it, you will never forget it. The adjustment is simple and can be done with a phillips screwdriver, you do not even have to remove the air cleaner.
Windseeker
EVO
07-04-2019 07:44 PM
robjohnston
12-08-2006 07:45 PM
