Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Rattle can clear coat?
Old 01-22-2011, 03:31 PM
Will-N-Missouri's Avatar
Will-N-Missouri
Will-N-Missouri is offline
Default Rattle can clear coat?
I have a 99 sporty, I painted it rattle can flat black, Im getting ready to hit it with black gloss out of a can, the problem is when filling up with fuel, if I spill any on the tankl it ****s up my paint job........I cant afford to pay the cost to have it done by anyone, so I was wondering what can if any of clear coat will protect the paint from fuel spill?
Old 01-22-2011, 03:37 PM
Mike T's Avatar
Mike T
Mike T is offline
You can find good clear coat in a can. Wet sand it when it dries and it'll really shine.
Old 01-22-2011, 08:53 PM
Nubs13's Avatar
Nubs13
Nubs13 is offline
If you go to a paint shop they will have a clear in a can that you have to pop a plunger on the bottom of the can and a harder is released into the can. You then shake it just like regular spray paint and spray. The nozzles are different than regular spray paint because they have a bigger fan of spray. A can of this type of clear will run you around $20 bucks, but it's well worth is since it has an harder in it.
They also spray reall nice. I hardly had any orange peel
Old 01-23-2011, 05:25 AM
abi's Avatar
abi
abi is offline
+1. That is the kind you need if you don't want the gas to eat your paint. Most rattlecan clearcoat will get damaged by gas just like any other kind of rattlecan paint.
Old 01-23-2011, 07:14 PM
Will-N-Missouri
Thank you for the direction, I will hopfully have her completed next weekend.
Old 01-24-2011, 12:58 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
here ya go bud! best you can get! it is a 2 stage clear in a can so it will hold up to gas, you can wet sand and buff i shoot it all the time man, all the time! even has a leveler in it to get a really smooooooth finish
http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
Old 01-24-2011, 05:11 AM
Nubs13's Avatar
Nubs13
Nubs13 is offline
Yep same stuff I shoot at the shop on small parts
Old 01-24-2011, 08:03 PM
Will-N-Missouri
It look's like this is what I need....Thank you.
Old 07-30-2012, 07:18 AM
rockerZ71's Avatar
rockerZ71
rockerZ71 is offline
do they have that clear coat in flat/matte? I can't seem to find it
Old 07-30-2012, 11:14 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
no they do not... just dont spill gas all over it and your will be fine i have used flat clear from rustoleum painters touch before and it held up great, i have also dropped a cup of gas on the tank after filling it in the garage, poured some water down on it and it was fine
Quick Reply: Rattle can clear coat?
