Initial indications of a compensator going bad
Old 01-22-2011, 08:30 AM
jimski's Avatar
jimski
jimski is offline
Default Initial indications of a compensator going bad
I would like to know what are the first indications or initial symptoms of a compensator that is beginning to go. This way I can be on the alert and have it taken care of before a total failure of the unit should I have that problem in the future.
Thanks to those that reply.
Old 01-22-2011, 09:45 AM
Bushrider's Avatar
Bushrider
Bushrider is offline
https://www.hdforums.com/forum/touri...mpensater.html
Summary: Big bang at startup (may or may not be a problem)
Sound like rocks or marbles rolling around in the primary.
I've been hearing the bang at startup but not the gravel-filled primary noise. I've subscribed to every thread I can find on the subject and will continue to monitor.
Old 01-22-2011, 09:48 AM
IndyClassic's Avatar
IndyClassic
IndyClassic is offline
Bang happens once in awhile.....rarely. No other symptoms so just keeping an eye on things for the time being.
Old 01-22-2011, 10:00 AM
redhwk44's Avatar
redhwk44
redhwk44 is offline
For what it is worth, my '10 Ultra would fire up with a bang occasionally. After I changed cams I no longer hear it. Not sure why but I noticed it right off the bat. I am sure the experts will chime in with a why. Without hearing the bang is there still a reason to worry? Is there damage still being done.
Old 01-22-2011, 10:01 AM
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
As others have noted, the "bang" or hard hit on start up. I also noticed some drive train surging or slack under low-load conditions as if the drive belt had a great deal of slack in it.
I've since replaced the stock comp with the SE version and that seems to have solved my issues...it's been fine for a couple years and many thousands of miles.
Hope that helps!
Old 01-22-2011, 10:04 AM
honestbob's Avatar
honestbob
honestbob is offline
When mine went I started getting what sounded like a bad starter gear but only when engine was hot. It would bang and jerk when I'd start up after getting gas or stopping for less then an hour. Sounded fine when starting cold. Finally took out the rotor.
Old 01-22-2011, 10:33 AM
Marine Trader's Avatar
Marine Trader
Marine Trader is offline
Would not the bang or backfire be caused by excessive fuel in the compression chamber on start up? I guess the next question is why was there excessive fuel in the compression chamber.
Old 01-22-2011, 10:47 AM
relli's Avatar
relli
relli is offline
been told compression and where the engine stops/starts from has the bang effect.
Old 01-22-2011, 10:48 AM
brgtr3's Avatar
brgtr3
brgtr3 is offline
Mine gave no warning, and when it went, it went big time! Here's a link to original discussion.
I replaced mine with the beefier SE unit (under warranty, only had to pay price difference).
https://www.hdforums.com/forum/touri...mpensator.html
Old 01-22-2011, 12:10 PM
jimsuver's Avatar
jimsuver
jimsuver is offline
My 07 sounds like its doing the same as yours did. I'm at 52K miles and wanting a SE comp. When you say it took out the rotor, is that the same as the stator?
Quick Reply: Initial indications of a compensator going bad
