Sponsored by: Jekill and Hyde
SE 203 cams compared to Andrews 21N
Old 01-21-2011, 02:44 PM
Oldfart666's Avatar
Oldfart666
Oldfart666 is offline
Default SE 203 cams compared to Andrews 21N
I posted earlier that I had a set of SEH 203 cams. What I wanted to know is how close the 203's are to the Andrews 21N(my choice of cams I was going to order) Sorry for all the question's,my first year on a Davidson since 1977.(they have changed slightly )
Old 01-21-2011, 03:30 PM
djl's Avatar
djl
djl is offline
Received 2,030 Likes on 1,498 Posts
As you can see, they are similar. Both have advance ground into the profile; 3* on the intake/exhaust on the 21 and 1.8* on the intake and 2/3* on the exhaust on the 203. For a cam only upgrade on a TC88, the 21 woudl be my choice. The earlier intake close is going to boost corrected compression which will make more low end torque. If the bike is a dyan or a softail, I mignt go for the 203 just to save money but the 21 is still a better choice for your situaation IMHO.
I/O I/C Duration Olap LSA Lift
SE-203 18/36 42/17 234/239 35 100.8 0.510/0.483
TW21N 10/30 40/8 220/228 18 100 0.498/0.498
Old 01-21-2011, 05:47 PM
fxstdsei03's Avatar
fxstdsei03
fxstdsei03 is offline
If you go with andrews or woods roller link conversion the 203s will not work. Those conversion kits require hybrid cams to work with the smaller inner cam bearings. Would have to be the N grinds from andrews or R grinds from woods.
Old 01-21-2011, 10:21 PM
tootal's Avatar
tootal
tootal is offline
I will just say it, the 203 is a POS! If you cruise a constant speed it feels like somebody is holding you back and letting you go and then holding you back... I love my TW 21! It is a wonderful cam and makes a huge improvement over stock even though the numbers don't look much different. Go with the TW21 but if you have to buy Harley then skip the 203 and go with the 204. It's much better! If you get a 4 degree key and a 204 you end up with a TW21. You can pull your heads and take a Dremel and take out the shelf below the valve seats. Basically remove the aluminum that sticks out from under the valve seat. Blend it in to the same diameter of the seat and you gain roughly 10 percent flow. This allows the TW21 to rev out rather well.
Gunny20
Engine Mechanical Topics
04-07-2015 06:59 AM
Sharkman73
18
09-04-2012 08:40 PM
steelerdude1
01-14-2011 09:24 PM
Called2Duty
11
08-06-2008 07:28 PM
aclass
01-26-2008 01:16 PM
Quick Reply: SE 203 cams compared to Andrews 21N
