Touring 103 CAMS
Old 01-18-2011, 08:16 PM
Pittsburghglide2010's Avatar
Pittsburghglide2010
Pittsburghglide2010 is offline
Default Touring 103 CAMS
OK What is your favorite cam for a Touring bike with a 103. I want to know what you all think. I dont want to hear go 107, go 131. I want to know if you only had a 103 in your Scoot what cam would you desire and why ..............
Old 01-18-2011, 09:05 PM
djl's Avatar
djl
djl is offline
Received 2,022 Likes on 1,494 Posts
TMan 525 or Andrews 54, maybe the 32 for solo touring and Andrews 26 or 48 or Woods 5-6 for two up and loaded touring; you could throw the SE255 into the last batch as well.
Why, because the are good cams for the application; all low and midrange peformers.
I am sure someone will throw the new Woods 555 into the mix but I don't know anything about it.
Old 01-18-2011, 09:20 PM
ravenron's Avatar
ravenron
ravenron is offline
204 cams in my stroker 103...
Been very happy with lots of low/mid torque. Dyno numbers were 96hp/105Tq.
Ron
Old 01-18-2011, 09:21 PM
gregsdart's Avatar
gregsdart
gregsdart is offline
Default cam
se255- a real gain from idle on up, no loss of roll on torque. We have a FLHTK with a 103, added the cams, tuner and aircleaner. Stock mufflers. Very nice increase and we can here the radio!
Old 01-18-2011, 09:33 PM
GoPro Steevo's Avatar
GoPro Steevo
GoPro Steevo is offline
I just ordered the Woods tw555 this morning from Fuel-Moto USA. Click on the FuelMoto link on the right side of this page, they have all the dyno charts you need to see. The cams are actually made by Andrews, to Woods specs. Here is a good dyno comparison between the TW-555 and the SE-255. All I needed to see...
https://www.hdforums.com/forum/fuel-...t-archive.html
Old 01-18-2011, 09:35 PM
roadgliderick's Avatar
roadgliderick
roadgliderick is offline
i just did a woods 555 cam install on a 96 and iam real happy with it and this cam can be used in a 103 talk to keith at fuel moto they have done that same install on a 103. but u will find that there are alot of differant cams that can be used u just need to figure out what kinda riding will u be doing mostly. good luck on your decision.
Teardrop's Avatar
Teardrop
Teardrop is offline
https://www.hdforums.com/forum/touri...ited-dyno.html
Read the thread posted above and check out the torque curve. I bet that bike is a blast to ride. When I upgrade my bike I will be going with a SE204.
Old 01-18-2011, 09:36 PM
roadroids's Avatar
roadroids
roadroids is offline
Wood 6-6 is a great touring cam with nice power across the board - solid flat torque curve.
Old 01-18-2011, 09:46 PM
emwolb's Avatar
emwolb
emwolb is offline
i've got the hd 259-E cams in my 08 streetglide and the cams perform great throughout the rpm range, from off idle to redline. they have .579" lift, and work really nice.
Old 01-18-2011, 09:56 PM
TOMCENTRAL's Avatar
TOMCENTRAL
TOMCENTRAL is offline
Cycle Rama 575's in my 2010 FLHTK.
1)Quiet
2)Smooth
3)Power:104tq & 60hp at 3000rpms(92hp max hp)
Regards,Tom
Quick Reply: Touring 103 CAMS
