Will a Buell frontend fit on a Dyna
Old 01-01-2011, 10:59 PM
Titan56's Avatar
Titan56
Titan56 is offline
Default Will a Buell frontend fit on a Dyna
I have an 03 Lowrider and was wondering if a Buell Frontend would fit. If so, what frontend?
Old 01-02-2011, 03:12 AM
FastHarley's Avatar
FastHarley
FastHarley is offline
Former Sponsor
Yes it will. Will it work properly? No What do you think all of those parts are in the inside of the forks for? You will need to change the shims (valving) and spring to the proper weight you are adding to the forks (your bike and what you are doing with it) Is the wheel strong enough to withstand the additional weight the heavier bike with added luggage? You need to research the wheels designed load specifications. If you are riding the bike and the wheel fails, you will be the first to know you screwed up. This is what is inside of them. If you are asking others here what front end will work on your bike without knowing what all component designed weight limits are, you should not be involved in a major component change such as this. Here is what is inside of them (XB1200L):
Old 01-02-2011, 10:04 AM
Fatbob_Bob's Avatar
Fatbob_Bob
Fatbob_Bob is offline
yes it will work....alot of the street pro guys in ahdra do it as well as the g2 racing street bikes.......I have a set of triple trees for sale that will mount a set of buell xb forks to a softail or dyna..let me know if its something you might be interested in
Old 01-02-2011, 10:06 AM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
Have you looked into similar styled inverted forks. They aren't much more $ than a used Buell front end and can give you the same kind of style. And if you shop smart you can get one that will allow you to reuse most of whats on the bike now like risers, bars, brakes, wheel and fender.
Old 01-02-2011, 11:03 AM
Titan56's Avatar
Titan56
Titan56 is offline
Just been looking at different options to get rid of my narrow glide front end. Been trying to find a factory 03 Wide Glide front end and having no luck. So started looking at the Buell front ends but your probably right to light for my bike. I do not want to get into revalving the forks. Just want to put a wider and more stable front end. Also want to reuse my wheel/fender and brakes.
Old 01-02-2011, 12:38 PM
teqsand's Avatar
teqsand
teqsand is offline
Big Kahuna HDF Member
there are places out there that you can parts to do this...
People were buying the cheap buells and going chopper with them
http://www.custom-choppers-guide.com...-choppers.html
http://www.bitterendchoppers.com/SportyFrames.html
GoOrdnance
01-19-2018 06:39 AM
ImTheDamnDECOY
11-19-2017 08:45 PM
sickboy75
08-16-2014 10:16 AM
DieselJoe
04-10-2014 08:44 AM
Machete23
08-21-2013 04:59 AM
Quick Reply: Will a Buell frontend fit on a Dyna
