69461-06B Trouble or not?
Old 12-22-2010, 08:51 PM
chevynut252's Avatar
chevynut252
chevynut252 is offline
Default 69461-06B Trouble or not?
I recently installed the 69461-06B Auxiliary Running Light / Brake Light / Turn Signal Conversion Kit to my FLHand it works nice and I like the extra brightness that lets the followers know I am there.
But,
I think I have a problem and hope there is an easy solution. I turned the ignition to accessory to listen to the radio and noticed that the turn signals/ running lights are on in the rear. The tail lamp is not. They turn off with the ignition turned off but are on during riding and accessory mode. Another rider with the same adapter on his Road King does not have this happen.
Does anyone know if FLH's do this or how I can fix it? Maybe it is defective from the factory? Maybe others have the same issue?
Thanks.
Old 12-23-2010, 07:11 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
Old 12-23-2010, 07:37 AM
jluvs2ride's Avatar
jluvs2ride
jluvs2ride is offline
Location: Back in the Good Ole USA. South Carolina to be exact.
Call the folks at Badlands.
http://www.badlandsmotorcycleproduct...cts/BETCSM.htm
Their stuff is first class and works great.
Old 12-24-2010, 11:05 AM
chevynut252
I read the other thread but may have missed anywhere that it said that the lights stay on when the ignition switch is turned to accessory. The lights work great when I'm riding and there is no problem with the brightness. My situation is that they stay on except when the ignition is switched to off.
If I listen to the radio where ever I am, with the engine turned off, the lights are on.
I did not want to do this but guess I will pull the meter out and check the contacts. This cycle does have another issue with the accessory switch on the fairing; I don't know where it leads to! I have the glo lights plugged into the harness behind the side cover but this 2008 did not match the Harley harness as far as wires leading to the right place. I have two hot wires to where there should be a hot and negative and the switch does not kill either of the hot ones.
Merry Christmas!
Old 01-09-2011, 10:56 AM
chevynut252
Default #69462-06A module still can't find problem
I looked at aftermarket kits for extra lights and have not found anything that I want to try until I figure out what is wrong with the factory #69462-06A module. I have read another post that explains all the wires in the harness and I see something about the accessory harness involved with the tail light harness, or maybe I read it wrong. This caught my attention because my accessory harness gave me a problem also. I bought the HD Glo Lights that plug into the accessory plug but they would not work because all the contacts were POS with no ground. And, the accessory switch does not switch off any of the POS hot wires so the glo lights are on whenever the engine is running.
I'm still confused as to what could be wrong with a totally stock, factory wired FLH and will be doing a meter run through before next spring!I'm still open to ideas from others who have had this issue.
Old 10-26-2011, 01:07 PM
Rad Dog's Avatar
Rad Dog
Rad Dog is offline
ChevyNut252,
Did you ever get this issue fixed? I have the same exact issue on my 2006 street glide
Thanks,
Steve
Trigger33
07-13-2014 04:56 AM
harleysteve
06-05-2012 12:27 PM
Staggerty
07-08-2011 12:24 PM
84 SOFTAILCUSTOM
04-29-2008 08:03 PM
mike b
02-12-2006 02:29 PM
Quick Reply: 69461-06B Trouble or not?
