2011 103 Engine running hot. Any ideas why?
Old 11-23-2010, 07:53 PM
coonoffrisco's Avatar
coonoffrisco
coonoffrisco is offline
Stage II
Question 2011 103 Engine running hot. Any ideas why?
I just bought a 2011 Electra Glide Ulta Limited with a 103 engine. I have found the primary and heads run hot and stay warm after the bike has sat for some time. Fluids are checked and at the correct levels. Any ideas?
Old 11-23-2010, 08:08 PM
TCMAN's Avatar
TCMAN
TCMAN is offline
By hot, what do you mean; they all run fairly hot and will take time to cool down when parked. Of course cooler weather they cool quicker.
Old 11-23-2010, 08:10 PM
Garcou's Avatar
Garcou
Garcou is offline
your going to need to get a tuner on that bike, meaning a power commander, fuel pak, sepst, tts, thundermax or what ever you desire, bikes come lean from the factory, good idea to change the air cleaner when you add a tuner as well, check out fuel motos website
Old 11-23-2010, 08:11 PM
dan conner's Avatar
dan conner
dan conner is offline
have you removed catalytic converters and richened up air/fuel ratio? temps. are lot cooler in bay area...you could not stand it stock in south texas.
Old 11-23-2010, 08:12 PM
Turbo Turtle's Avatar
Turbo Turtle
Turbo Turtle is offline
It's an air cooled engine. Did you have a digital thermal gun to confirm it's hotter than the rest of them?
After you park, theirs nowhere near as much airflow around the motor. Plus it's a cat bike, and they are likely to run a bit hotter than a few year older one. I say get over it and ride.
my $0.02
aka Bob
Old 11-23-2010, 08:13 PM
FDHOG's Avatar
FDHOG
FDHOG is offline
How many miles on it? Bike will run a little hotter during break-in. Also you have a cat in the head pipe.
My 103 runs about 220-250, but I have a canned map and V&H Power Duals/Monster Rounds.
Going for a tune next week should bring the temps down.
Get an oil temp gauge. What you're feeling might be normal temps.
2011FLHTK's Avatar
2011FLHTK
2011FLHTK is offline
Its an extremely hot feeling engine, but I've been told that it feels hot because it dissipates heat very well (and runs relatively cool).
Old 11-23-2010, 08:15 PM
arealinvestor's Avatar
arealinvestor
arealinvestor is offline
What hot?? You have temp guage? or oil temp guage? They all run hot like previously stated!!
Old 11-23-2010, 08:16 PM
R.Rains's Avatar
R.Rains
R.Rains is offline
Thumbs up Cat
Grab the CAT by the tail pull him throw the pipe so the HOG can breathe. This is a good place to start.
Old 11-23-2010, 08:24 PM
Steel Billet's Avatar
Steel Billet
Steel Billet is offline
Lean lean lean
Quick Reply: 2011 103 Engine running hot. Any ideas why?
