View Poll Results: A poll
Yes
40.30%
No
22.39%
I use black wire raps now.
34.33%
Mine fell of and I dont have one any longer.
2.99%
Voters: 67. You may not vote on this poll
Battery Cover Clips 06 Sportster
Old 09-23-2006, 11:34 AM
sumncguy's Avatar
sumncguy
sumncguy is offline
Default Battery Cover Clips 06 Sportster
So far mine has been in to get the clip put back on. The first ride after the service, I dropped the battery cover on the road and had to turn around an go pick it up. Luckily minor scratches. The clip is not covered because its considered a wear and tear item. The only reason mine was opened up was the clips failed.
The bike is new and I just got the Harley survey and want to know how many people are experiencing this issue and if they are isolated incidents.
So, the question is - Does/do your Sportys battery cover clips suck ?
Old 09-23-2006, 11:55 AM
jshall755's Avatar
jshall755
jshall755 is offline
Default RE: Battery Cover Clips 06 Sportster
Mine are fine so far... I've only had the cover off once. If you can, you may want to edit your question in the poll to reflect your question in your post. My first thought was: yes, I still have battery clips. Instead, after reading your post, I voted mine don't suck... yet (or they do and I don't know it).
Old 09-23-2006, 12:35 PM
eggroll's Avatar
eggroll
eggroll is offline
If pulling the cover off only once leaves the clips in a questionable state of re-use, then the answer can only be "yes, they suck." Using an unreliable clip to fasten a necessary part seems counterintuitive. [sm=confused06.gif]
Old 09-23-2006, 01:10 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
"Wear & Tear" my a$$. I've had 3 different clips replaced, no charge. I think the newest version works. Haven't had a problem with the last one. I'm not sure, but I'd say it's been on for at least 3,000 miles.
Old 09-23-2006, 04:17 PM
ronn39's Avatar
ronn39
ronn39 is offline
I've had the battery side of my '04 on and off quite a number of times (I tinker), and no problem -- yet.
Old 06-02-2010, 09:57 PM
vabikersteve's Avatar
vabikersteve
vabikersteve is offline
Default Sportster battery cover clips
I came back from Rolling Thunder with the battery cover gone from my 04 883xl custom. A month ago, I replaced the worn clips with new ones from H-D and all seemed well.
Now I'm looking for a reasonably priced replacement cover.
Old 06-03-2010, 01:57 AM
Steeler's Avatar
Steeler
Steeler is offline
Default Howzit
I had mine come loose after i collected it from a service,i held it in place with my left foot untill i could pull off,it helped i was ridding mid controlls,I actually felt it unclip ....back home i drilled a small hole in the top side and cable tie it to the frame.H
Old 06-03-2010, 05:12 AM
Thumper26's Avatar
Thumper26
Thumper26 is offline
Mine fell off and I never knew it. Picked up a new one and "zipped" it on. All is good.
Old 06-03-2010, 12:47 PM
badger1984's Avatar
badger1984
badger1984 is offline
There is a new part from the MOCO and I installed it when my cover fell off the week after my 1200 upgrade was done. I went in and talked with the service manager and he was really cool and GAVE me a replacement cover at no charge...but I had to buy the $10 cover clip. I have had it on for over 3500 miles since and it works great.
Old 06-03-2010, 01:55 PM
Thumper26's Avatar
Thumper26
Originally Posted by badger1984
There is a new part from the MOCO ... I have had it on for over 3500 miles since and it works great.
Got a part #?
Quick Reply: Battery Cover Clips 06 Sportster
