Sponsored by: Jekill and Hyde
SE Air Filter
Old 06-24-2005, 11:01 AM
rm4040's Avatar
rm4040
rm4040 is offline
Default SE Air Filter
I notice on the New SE air kit that the filter must stay dry whereas the K&N is coated with oil. Is there any opinions which is better
Old 06-24-2005, 11:13 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default RE: SE Air Filter
Hands down , the K&N, I think HD is going back to the K&N because of problems with the perty blue thing coming apart.
Old 06-24-2005, 12:16 PM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
The K&N is tons better. I feel better being able to wash out the filter to clean it. I clean mine with Varsol, let it air dry, then re-oil it with K&N spray.
Old 06-25-2005, 12:28 AM
michaelrkc's Avatar
michaelrkc
michaelrkc is offline
Maybe a dumb questin, but can the "perty blue" filter in the new SE kit be replaced with the K&N at replacement time?
Michael
Old 06-25-2005, 12:42 AM
cash's Avatar
cash
cash is offline
And are they interchangeable without remap?
TC
Old 06-25-2005, 01:13 AM
lschultz's Avatar
lschultz
lschultz is offline
If you are wanting to change the SE air filter to a K&N they do not have one listed on there site yet. They have a listing for the stock HD air filter if that is what you have but not a replacement if you have had the Stage I done.
Old 06-25-2005, 10:10 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Check out this listing
REVERSE TAPERED FOR TWIN CAM AIR CLEANERS
7" Diameter metal top has centered 5/16 NC weld nut to attach cover
Top plate is 3 hole drilled to fit standard mounting pattern for Twin Cam air cleaners
6" Diameter molder rubber base
Customer must supply own mounting spacers
Height Part No.
3 1/4" HD-0700
Top plate is 3 hole drilled to fit standard mounting pattern for EVO air cleaners
Check height needed by part number
Height Part No.
2 3/4" E-3227
3 1/4" E-3228
Found here http://www.knfilters.com/harley_custom.htm
They DO have what you are looking for because they make them for HD, try calling them. I took these numbers off the extra one that I have on the top rubber edge A055E4 and 130 if they help off a 03 SE deuce.
Old 06-25-2005, 12:52 PM
h60mech's Avatar
h60mech
h60mech is offline
Not to sound stupid but if I may ask a question. What is comprised of a stage 1 kit? Recently A friend of my came back from the states and brought me a SE air filter and one jet ( not sure of size since it's at my work). I got the P/N for the air filter from the HD SE web site for my 05 Fatboy( picking it up Aug 1). My friend also told me he stated to the dealer what it will be for ie: Model Carb etc. just to be sure he gets the right one also. (can't take it back until the next visit back to the states). I guess what I'm asking is should I wait to put this on? being that what I'm reading the K & N is coming back? Or should I go ahead and have it installed. I've also read that there are 2 jets. Why would the dealer only give me one? Hope this makes sense. Any advice is appreciated
John
Old 06-25-2005, 01:49 PM
traveler's Avatar
traveler
traveler is offline
You might want to check on the Harley-Davidson website, since they have a contact number for you guys in other countries. Let us know what comes of it though......I really want the K&N verses a paper one. First of all, the K&N will outlast you if you clean it and oil it regularly, and treat it right (i.e. put it on carefully, don't cruch it down by overtightening, etc, COMMON SENSE i guess...) and unless you live on a dirt road, it will only need to be maintained maybe once a year, unless you get into a lot of water, rain etc., I guess you just have to keep an eye on it. I personally LOVE K&N's.
If you guys get any more info on this let me know. I'm stopping by the dealer today, and i'll ask them about this, and let you guys know what I find out, if anything.
joe
Old 06-25-2005, 06:25 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
rm4040
Here's the part number for the HD replacement filter for the stage 1 upgrade PN 29442-99A . This is the oil coated K&N
It needs a cleaner to service it PN 99883-88T
and an oiling with PN 99332-88T
Hope this helps you out
Quick Reply: SE Air Filter
