Deutsch Crimp Tool
Old 11-16-2010, 09:20 AM
peddler's Avatar
peddler
peddler is offline
Default Deutsch Crimp Tool
Anyone use one of these to crimp pins and sockets on a Deutsch connector. This one sells for $29.00. All the other tools I've found sell for over $200.00. All ideas input welcome.
D-sub Dt Series Deutsch Crimping Tool 20-12 Awg
Old 11-16-2010, 09:56 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Peddler, I've only used the two crimp tools (Philmore WS26, $7.99 at Fry's Electronics; and, BCT-1, $25 from Great Plains Electronics) mentioned in UltraKla$$ic's thread and in your reply in post #48:
https://www.hdforums.com/forum/touri...achable-2.html
The BCT-1 tool (actually a Sargent tool) works equally well with Tyco AMP and GM/Delphi weather seal pins/sockets in additon to the Deutsch crimps.
Nice find on the tool you pictured. Do you have a link? Manufacturer? Does it do both crimps simultaneously?
Carl
Old 11-16-2010, 10:00 AM
1931jamesw's Avatar
1931jamesw
1931jamesw is offline
Sounds like it could be a good buy if its something you wont use alot. My experience with tools is you get what you pay for and the ones Ive seen, as you said, go for as high as $350 but if you arent going to use it all the time, it may get the job done for you.
Old 11-16-2010, 10:54 AM
rpeters282's Avatar
rpeters282
rpeters282 is offline
hollow pins and a soldering iron....no need for a crimp tool.
Old 11-16-2010, 11:06 AM
bmaier's Avatar
bmaier
bmaier is offline
Ive only used an expensive CAT brand deustch crimper. Nice tool to have but I use it so infrequently im better off just borrowing it.
Old 11-16-2010, 11:12 AM
Garemlin's Avatar
Garemlin
Garemlin is offline
Great find. I haven't seen a Deutsch connector tool for under $200. Might have to pick one of these up and give it a shot.
Old 11-16-2010, 11:17 AM
dawg's Avatar
dawg
dawg is offline
Received 2,969 Likes on 1,718 Posts
Old 11-16-2010, 12:44 PM
bikehe's Avatar
bikehe
bikehe is offline
Does it have the spring in the centre where the pin goes into the crimper? The $200 pair I have allows you to do a first crimp then push the pin in against the spring tension in the tool and you get another crimp on the ferrule.
Old 11-16-2010, 02:05 PM
BAGGERNATE's Avatar
BAGGERNATE
BAGGERNATE is offline
tag for ref
Old 11-17-2010, 08:22 AM
jake0matic's Avatar
jake0matic
jake0matic is offline
The only one I have ever used is also the one that Caterpillar supplies in their electronic repair kits for Deutsch connectors, I looked in to purchasing one for myself and it was over 200.00. I may just buy this and try it for a whopping 29.00, hell I've spent that at the bar and still have nothing to show for it.
Quick Reply: Deutsch Crimp Tool
