Duel plug heads????
Duel plug heads????
Hey Guys I just bought my first HD, it an 1982 FXS lowrider, I have no ehistory on the bike. My question is are the duel plug heads stock or after market?. I'm sure I'll have many other questions as time passes and I clean it up over our long Canadian winter. Thanks in advance for you r feedback
Hufee
Hufee
Duel plug not stock I did a 93CI shovel with duel plug heads and single fire Don't know if the 2 plugs per cylinder helped but the bike was impressive It looks good with all the plug wires running around You can also run compression release plugs off the unused plug holes if you ever want a high comp stroker motor
Not stock but a very nice addition for a shovelhead , solves a few chronic problems like fussy starting and dirty spark plugs . You can run the cheap pump gas without knocking and pinging . I've dual plugged every shovel I've ever owned and about 70% of the rebuilds I do for people . When doing a tune up you may find the bike will run better with the timing backed off a few degrees . Looking in the timing hole you see the mark on the flywheel centered is 35 deg. , move the mark to the rear of the hole so you just see it that,s 2 1/2 deg retarded . I've found that or a hair more is the sweet spot for shovels & dual plugs .
I go along with Twizted here the line on the wheels should be centered at the normal advance mark (front cylinder ) for timing By bringing this line to the rear slightly The bikes seem to run better Maybe because I run the 52 with the line at the rear of the timing hole (circuit breaker ) or maybe we're both retarded
Received 3,212 Likes
This may come as a complete shock to many folks but dual plugs ain't what most think. We have dual-plugged Pans, Iron & Evo XL's, Shovels, Evo's and Twin Cams, over the almost 3 decades we have been in business.
Small engines, as well as large powerplants.
NEVER had we EVER experienced anything earth-shattering, in regards to doing so, while dyno testing/tuning later, and trust me, we shook the trees.
Machine heads, 4 plugs, 2 sets of wires, multiple coils, specialty coil mounts, usually along with a single fire ignition.
Let's see...........650.00 plus dollars for no more torque, or hp, in a street driven bike.
Think I'd rather have a bar of soap.
Scott
Scott
__________________
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Maxton Mile World Record
4500 sq ft. facility
See us on Facebook.
Crank Rebuilding
See us on Facebook.
