Formula Plus or Not?
Old 11-01-2010, 07:58 PM
14/88trucker's Avatar
14/88trucker
14/88trucker is offline
Default Formula Plus or Not?
I have a 2006 FLHTC. I recently went to do a service myself now that my warranty is off and found out that they reccomend Formula Plus in my primary and tranny. After talking to one of the techs at my loal Stealer, he told me that most people are running 20/50 full synthetic fluid. I have always run the RevTek 80/90. What should I run?
Old 11-01-2010, 08:35 PM
skidder's Avatar
skidder
skidder is offline
Lots of riders use formula plus. I use Belray primary, it's an 80 wt.and in the gears I use Belray Bigtwin gear oil, it's an 85-140wt.
I think the Formula plus is a 50wt.
Old 11-01-2010, 09:41 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Formula + is ok for the primary but I would stick with the 80w90 in the trans.
coyote454 (10-05-2016)
Old 11-02-2010, 04:15 AM
mtclassic's Avatar
mtclassic
mtclassic is offline
I would bet there is more formula plus in primaries and trannies then all the other oils put together on newer harleys. My basis for this is that that is what harley recommends and I bet the majority of the sheep I mean people use it with good results. Literally you could probably use a stick of butter in the tranny and be okay.
Old 11-02-2010, 07:32 AM
peppi's Avatar
peppi
peppi is offline
Formula+ is OK for the primary but many better choices for the trans. Try the Spectro gear oil in the trans, you'll be glad you did.
Old 01-29-2011, 11:54 AM
TedMan's Avatar
TedMan
TedMan is offline
+2. I use Mobile 1 gear oil in tranny. Formula + works well for me but only in the Primary.
TedMan
Old 01-29-2011, 05:49 PM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is offline
Received 1,398 Likes on 450 Posts
I've used 3 oils so far in my primary on my 08 FXSTC. Syn 3, Amsoil 20/50, and Formula +. Of the 3, I like the Formula + better than the other 2.
jimski
02-18-2012 07:14 AM
bdavis385
08-18-2010 11:16 AM
Bluegrasser
04-16-2010 12:17 PM
2006 ultra classic
03-29-2009 04:37 PM
Mad Dawg
01-18-2007 12:28 PM
Quick Reply: Formula Plus or Not?
