Changing Throttle Cables...
Bill explains how they slide the tank out of the way instead of removing it here,
http://www.youtube.com/watch?v=LEE2R...os=mzyWWoCQfm4
Once the main fuel line was popped off using that great little quick connect, the tank slid back far enough to get to what I needed.
Cables in all good.
These new braided ones seem to run a whole lot better than the stock. Much smoother.
Cheers
-J
Its a pull-pull system. The best way to adjust them is to undo both the adjusters until the throttle has a lot of play in it. Then turn the bars all the way to the right and adjust until the throttle is tight, but without binding.
Then turn the bars to the left and adjust again to take out the slack. Test by turning bars both ways.
Great video, did you ever continue making another showing the throttle cable replacement?
Jb
RaceFace
08-04-2012 11:53 PM
