testing the horn
Old 10-24-2010, 01:20 PM
laythss's Avatar
laythss
laythss is offline
Default testing the horn
Hi all, on a 1985FXR, i have a horn (tan wire coming out of it). I wanted to test if horn is working or not, so here is what i did:
I connected the battery then i took the loose end of the tan line (going to the handlebar switch) and touched the positive terminal of the battery, a spark occurred but no sound.
Does this mean the horn is bad, or am i thinking of this wrongly?
Layth
Old 10-25-2010, 01:59 AM
sbyumabaker's Avatar
sbyumabaker
sbyumabaker is offline
1. Your horn should work with 12vdc one side and ground on the other : the horn is not polarity sensitive.
2. With key in on position test to see if the tan wire is ground or the 12vdc. Bike might not be wired with OEM color code.(colors I'm used to are Yellow/black and black)
3. Best test will be to disconnect wire from horn and then ensure you have a confirmed ground on one side and 12vdc on the other; horn should turn once wires are connected. If it does not work replace horn>>> just my 2cents.........Good luck
ronaldrwl
09-22-2018 11:58 AM
Razo
08-17-2018 07:05 PM
raybagger1
04-19-2017 10:48 AM
brandss
06-14-2012 10:13 PM
gas4harley
Electrical/Lighting/Alarm
03-26-2009 10:26 PM
Quick Reply: testing the horn
