Andrews 26 vs S.E. 203
Old 10-23-2010, 11:17 AM
2005 Roadking's Avatar
2005 Roadking
2005 Roadking is offline
Default Andrews 26 vs S.E. 203
I got A deal on a S.E. big bore kit with cams. Also bought S.E. hybrid cam plate/oil pump kit with hyd. chain adjusters. Bought a set of 26's also. I have a 05 Roadking, that I ride mostly 2 up. Which cam do you guys think would be better for my riding style. I a thinking The 26's.
Old 10-23-2010, 11:33 AM
Rat1's Avatar
Rat1
Rat1 is offline
I have the 26s and I like them. Never tried the SE 203 cams so I can't comment on them.
Old 10-23-2010, 12:09 PM
stro1965's Avatar
stro1965
stro1965 is offline
I have 26's as well and really like them. I think the 26's might be better compared to the 204's, whereas the 21's would compare to the 203's. But then again, I usually have no idea what I'm talking about!
Old 10-23-2010, 12:13 PM
fripple's Avatar
fripple
fripple is offline
I would do the 26 over the 203, but that's just my opinion.....
Old 10-23-2010, 12:16 PM
leohd's Avatar
leohd
leohd is offline
203's are great for reliablity but ARE JUST A TOUCH BETTER THEN STOCK, if you want power 26's
Old 10-23-2010, 02:08 PM
badjustbad's Avatar
badjustbad
badjustbad is offline
I have the Andrews 26s in my 08 RKC (96"). I recently bought an Ultra Limited with the 103". The 96" with the 26s blows the doors off the 103". Mind you, the Ultra is heavier and still stock, but it gives you an idea of the performance you can expect.
Old 10-23-2010, 02:25 PM
petemac's Avatar
petemac
petemac is offline
I put the 26N's in my bike when I did the hydraulic cam shoe adjustment upgrade. 26's perform great.
Old 10-23-2010, 02:38 PM
steelhead's Avatar
steelhead
steelhead is offline
I went back and forth between the 21s and 26s. Can't compare to the 203s but can say I am happy with the 26s.
Old 10-23-2010, 03:41 PM
Mike's Avatar
Mike
Mike is offline
The Andrews 26 cams have an even more conservative profile than the 203s. (.490 lift, 226* duration, 20* overlap vs .510 lift, 234* duration, 35* overlap). On paper, the 203s should outperform the 26s, as long as you've got the right tune and exhaust. Either one will work well in a touring bike, both cams are good examples of taking a stock cam and adding just a little lift and overlap to achieve good gains.
Old 10-24-2010, 08:57 AM
2005 Roadking
Well 26's it is. Thanks for info. & feedback.
Hozza
05-25-2018 06:05 PM
custom_fatboy
Engine Mechanical Topics
05-21-2014 12:12 PM
scasey
05-22-2011 08:32 AM
ElectraHead
02-17-2011 09:53 AM
hougz79
09-06-2010 10:20 PM
Quick Reply: Andrews 26 vs S.E. 203
